Well, I just increased the off delay. Download and see if that helps. Later I'll see if I can make that adjustable. It will have to be longer eventually since Windows 7 has that fade off which shortens the off time as well.
Hi Curious,
Could you please make the video sync timing adjustable?
My video sync works perfectly in the summer, and i haven't had a funny screen in quite sometime, but lately when the winter has gotten extremely cold it doesn't work so well at the current timing.
Thanks!
awesome, thanks!
Will report back!
500ms isn't enough, still got out of sync screen.
Maybe 1 or 2 seconds would be ok for this terrible winter we're having.
Wow, that's getting bad. OK, download it again. This time run it and then quit (without enabling ports). Run regedit and go to HKEY_CURRENT_USER\Software\CuriousTech\XPort3
You'll see VSyncDelay REG_DWORD 2. (2= 200ms) Change that to 10 for 1 second.
Run xport again.
I'll add that to the GUI later. It's getting cramped.
I'll give that a shot.
Its been floating around -30*C/-22F here so everything is significantly colder.
Thanks for the help!
looks liek the weather has warm up and 500 ms would be sufficient.
