Results 1 to 10 of 12
Thread: after a startup, GPS not founded?
    Oct 2007
    NY
    everytime i start my carpc up from a hibernation, the GPS port is always lost even though its plugged in...sometimes i would need to unplug and replug the GPS back in and then rescan with Xport and then its found. anyone have a solution for this? thanks.
    FLAC Marvin Hlavac's Avatar
    May 2005
    Your operating system may have an option to keep USB ports powered even while hibernating. Check if that option is enabled. If it's disabled, enable it. If that doesn't help, I think I heard some people say GPS Gate software may help with this issue.
    Others may have better ideas for you to try. I've personally never experienced this problem, so I have no first-hand knowledge in this area.
    Oct 2007
    NY
    thanks for the response Marvin..ill see if i can find that option.
    Jan 2006
    LiCelsior, did you find a solution to your problem? I'm having the same issue with my setup, running Centrafuse and a BU-343 GPS Receiver. Occasionally, when I start my system (it resumes from hibernation), the GPS unit isn't found, so it doesn't pickup any signal. I have to go into Centrafuse's GPS settings and set the COM port again, and then, usually, it will find the GPS unit and it picks up a signal straight away.
    Any ideas?
    Oct 2007
    NY
    I just have to now use x port to rescan and it picks it up again. Wish it held the USB in memory though.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Does the port number change each time, or does the scan find it on the same port? XPort auto-reconnects so I'm assuming the former.
    Oct 2007
    NY
    It scans and finds the same port.
    Mar 2004
    Florence Yall, BFKY
    Definitely an older version of XPort.
    Oct 2007
    NY
    is the current version 1.41?
    Mar 2004
    Florence Yall, BFKY
    Yes, 1.41 is the latest. The bottom of the window shows current status of the port, such as Port Doesn't Exist, Port Closed, Port Open Failed: (windows error number), Port Open Timeout, etc.
  1. Replies: 353
    Last Post: 08-24-2009, 09:31 AM
