support computer standby?
Hi
Does anyone happen to know of a GPS model / software that would support computer standby?
Possibly even re-initialize the GPS antenna when waking up?
I wanted a GPS system that support instant-on. Pocket-pc would work, but the screens are too small for movies. So I tried a laptop with Delrome + Street Atlas 6. But the GPS consistantly crashes win-xp in the wakeup process.
Any hints would be appreciated.
I use the randmcnally serial gps plus ms streets 98. I actually use hibernate and not standby, so I don't know what happens if I use standby. However in hibernate the gps wakes up compleltly by itself with no complaints and will reaquire on its own. The only problem I have is streets 98 will send a message that it hasn't detected a satelite lock in a while but it will relock and track on its own.
Something I think might be a problem is USB seems to have a problem waking up so if you are using a USB antenna that might be your problem. I also use win2k.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
