Results 1 to 10 of 12
Thread: GPS starts only half the time
    Feb 2010
    Hi guys,
    i have a usb Global-Sat GPS receiver going to my laptop running Centrafuse on XP with the Destinator software for my navigation. The problem I am running into is that only about half the time I start up my computer it picks up the GPS signal, the other times its just an arrow with an X in it. I have found a quick solution to this which is going to settings, clicking navigation setup, not changing a single setting but hitting save settings and going back. after that i have a GPS signal. I guess my question is what could i possible be changing by saving no changes in settings? Theres gotta be a way to duplicate that at start up so it starts GPS every time. It's not a huge problem obviously it's just a little annoying and if anyone has encountered this and knows of a fix i would greatly appreciate it!
    thanks~
    Jan 2009
    I have the exact same problem only mine only works about one third of the time.
    I am considering upgrading to WINDOWS 7 and see if this helps.
    Jan 2010
    model / type of receiver?
    is it the USB puck, serial, or bluetooth?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    That's normal without XPort.
    Jan 2010
    Quote Originally Posted by Curiosity View Post
    Really? that sucks for you guys.
    don't need to do anything for me. just setup a delayed startup script to force nmea and it's good from then on...
    Then again, my setup doesn't look all fancy shmancy with a frontend. i just use a media player as a frontend. seems to work for me.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    That's normal with the latest XPort.
    Corrected for ya C.
    I have had to go to an older version as I found that the new one wasn't starting before the app that needed so the app would not connect.
    However went back to an older version and it works perfectly
    Mar 2004
    Florence Yall, BFKY
    Nooooooo! Really? 1.41 is the most agressive so far. I think it tries to connect a little sooner, but also retries lot.
    Feb 2010
    I am really new to this could someone tell me what XPort is? and also p057 mentioned a delay at startup script although Centrafuse has a built-n delay on startup that I do not have enable what should i set it for?
    Mar 2004
    Florence Yall, BFKY
  1. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  2. 1.0.4.7 bug
    By debugger in forum StreetDeck
    Last Post: 07-01-2006, 04:01 AM
