Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: Xport Trouble Experienced User.
  1. #11
    Apr 2007
    By the way, anyone still has version earlier than 1.41 to share? Thought it may be worth a try.
  2. #12
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Sorry guys. As far as I know, versions 1.40 and later have been unstoppable. There is a 1.42 but I forgot to note that on the site, so just updated it. Give it a try. Anything in the 1.3x range had a bad bug when the fix changed (none, 2D, 3D) though. But all of that code was removed quite a long time ago.
  3. #13
    Apr 2007
    Greg, thanks for responding. What do you mean by unstoppable?
    The download link on your site is still pointing to http://www.curioustech.net/downloads/xport141.zip
    Probably my ISP is still refering to the old cache. I'll try to download again tomorrow.
    Edit:
    Realise xport141.zip now contains 1.42.
  4. #14
    Mar 2004
    Florence Yall, BFKY
    That's the right one. I forgot to rename the zip, but the exe is 1.42
    It's been very stable for quite a while, and I think it was 1.41 that finally fixed all the messed up status problems I had. I haven't wanted to change anything for a while.
  5. #15
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    I guess I upgraded from 1.41 to 1.42 w/o knowing it. Cool, thanks!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  6. #16
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    1.42 seems to be the solution to my problem. Thanks Curiosity.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  7. #17
    Mar 2004
    Florence Yall, BFKY
    Well, still sorry about that. I thought 1.41 ended all the problems and 1.42 was just a few tweaks. Guess not.
  8. #18
    Feb 2003
    SE, PA
    same problem here, started last week
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
  9. #19
    Low Bitrate SoulR's Avatar
    Aug 2007
    I too also had this issue, started 1 week ago with suddenly my gps program (igo8) stating "GPS disconnected" (thought i was going mad).
    No windows updates, no changes nothing, it was working fine 3 days prior.
    I can see xport shows 3D fix, but GPS cannot detect the GPS receive. Looking at xport i can see the virtual port changes from red to green for about 30 seconds then changes back to red, then flickers green then back to red approx every 30 seconds from then on in. Funny thing is RideRunner which i have set to another virtual port looks like it's accessing the port fine? (says green).
    When i get time i will try 1.42 and report back.
    Send me a PM if i can help in troubleshooting in anyway.
  10. #20
    Oct 2006
    after putting version 1.42 and disconnect and reconnecting my GPS it worked, but back to the same problem after sleep/wake. There was an error saying failure open com port 2 i think.
  1. Xport not working with NG Topo!
    By JBeam in forum GPS
    Last Post: 05-01-2010, 10:28 PM
  2. Xport problem Newbie
    By Ausrod in forum GPS
    Last Post: 12-27-2009, 05:56 PM
  3. minlogon and user profiles
    By RedGTiVR6 in forum WinNT Based
    Last Post: 08-13-2006, 09:54 AM
  4. We Need Ratings.
    By Fusion-One in forum Mp3car Forum Suggestions/Comments
    Last Post: 06-11-2006, 09:16 PM
