Using xport to split GPS port. Only works after restarting xport?!
I am using xPort 1.44 and having some trouble with it. First off, when I start it up, "enable ports" is unchecked by default so I have to enable them. Occasionally it will stick and be OK after a reboot but when RR launches, the GPS data I use on my main screen does not have any valid data, and if I load iGuidance, it doesn't see the port either, but if i uncheck "enable ports" and re-enable it, the data starts appearing in RR and iGuidance. Is this a bug or is something screwy? I assume the easiest way to use this is by dropping it in the Startup folder, right? For now, I am going to try downgrading to an earlier version.
