Results 1 to 3 of 3
Thread: wi-fi and gps
    Sep 2010
    Lightbulb wi-fi and gps
    Hello!
    I'm looking for solution for a car/bus/boat etc., what should bring two things in one - internet (wi-fi) and GPS monitoring.
    DETAILS: Internet (from my GSM operator - separate sim card) could be spread by wi-fi for people on-board. I guess its easier part, here best solution will be 3g&wifi router (in one) with sim card inside. But GPS is a bit bigger challenge - got no idea what kind of gps module should I use and how to connect gps with router. GPS should be able to send information about position e.g. in each 5 minutes.
    Got no idea how to integrete this two things (how GPS could use internet connection). Or maybe already there are some in-box solution I don't know? (pls, recommend one)
    Thanks in advanced for ANY hints!
    Greetings!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    this is what my company uses for just that purpose its called fleet management or AVL and uses a gsm/gps unit to send position every 1-60mins or more depending on your data plan. here is 1 modem we use, its cheap http://www.enfora.com/index.cgi?Page...:CONTENT_ID=68 or one that is quite abit more money but has router built-in that can assign 32 ip's http://www.bluetreewireless.com/prod...teways-213.cfm the enfora is about 120.00 and the bluetree/sixnet is about 650.00. Both units will work on GPSGate server for a cheap monitoring solution hope this helps SNO
    Sep 2010
    Thank You very much for You answer!
    Im not sure if I understend You corect - the GSM modules You mentioned they are kind of industrial, I'm rather thinking about amateur-ordinary solution, e.g. router like this (link below)?
    http://cgi.ebay.com/UNLOCKED-HUAWEI-...item3cb0ce24c2
    Such ruter I wonna use to get intrnet (and spread wifi), but got no idea how to connect to it GPS module. And what kind of GPS modul should it be - I think it could be even the simplest one, but how I should connect it to router and how to force it to send location in e.g. each 5 minutes.
    Any ideas?
    Greetings!!
  1. Any XM GPS combos?
    By bns2000 in forum GPS
    Last Post: 11-05-2005, 10:13 PM
Tags for this Thread
