Results 1 to 8 of 8
Thread: GPS & Touchscreen not getting along
    Dec 2007
    SoCal
    So to be quite honest, I just about gave up on my carputer. But for some reason I decided to fire it up one last time before putting it up in the rafters of the garage.
    So I think I found the problem. I gave up on the carputer because my touchscreen would just stop working after a few mins (5 - 20 mins) after boot up. I decided to unplug my BU-353 and to my suprise, the touchscreen worked fine for hours. My touchscreen/monitor is a Xenarc 700tsv.
    My question is, why is this happening? I am also using xport to split my GPS to Riderunner and IGuidance 3.0. I have been out of the game for so long I don't even know what people are using any more.
    Any help would be great!
    Thanks,
    Nick
    WinXP Pro
    USB Touchscreen
    USB BU-353
    Maximum Bitrate DeltaFX's Avatar
    France
    Were they sharing the same USB controler ?
    Now Galileo is real. Muhahahahaha :p
    Maximum Bitrate SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    are they plugged into a powered or unpowered hub and are they using the same hub? I have found for touchscreen to be on its own and to the computer usb port using a good quality extension cable. I have my gps/skype phone/tpms/ads radio/ext. dvd all living happily on a powered hub and touch on its own, never a problem in a couple of years now SNO
    Dec 2007
    SoCal
    I am not running a hub. I have both of them plugged directly into the motherboard via the rear panel. I don't think they are sharing the same controller. What do you guys use to make copies of the gps port...I.e XPort?
    Nov 2009
    Keswick,On Canada
    try going to device manager and usb controllers/root hub and check if allow windows to turn off device is checked. It might be your problem since you are using direct to mainboard usb ports just a thought SNO
    Mar 2005
    To original poster
    I have the exact same problem, and never figured it out. It is hilarious to me if it is the GPS I have tried all kinds of stuff. Now I kinda want to try a different GPS and see if that fixes it or not. I used a garmin 18x for another project (the com port ones at 5hz) but maybe I will just get another USB one. Any suggestions for quick pickup and good signal quality?
    Quote Originally Posted by SNOtwistR View Post
    I found that made it happen quite rarely, but it still sometimes happens.
    Dec 2007
    SoCal
    I don't think it was the GPS that killed the touchscreen. I think it was XPort. I am using a BU-353. If I don't use XPort my Xenarc TSV700 seems to work fine for hours. If I am using XPort, the touchscreen stops working after ~15 minutes. One of these days I need to put it back in my 350Z and see if it still has problems. Maybe I will just run a 2nd GPS instead of trying to split the signal?
    Quote Originally Posted by sxott View Post
    To original poster
    Mar 2005
    Quote Originally Posted by SpinOut123 View Post
    Ah well I had xport as well, still it worked fine with a different GPS in the past.
  1. Replies: 65
    Last Post: 10-13-2009, 06:51 PM
  2. Replies: 91
    Last Post: 11-07-2006, 04:47 PM
  3. opus power supply, xenearc touchscreen, gps
    By bryce_thomason in forum Classified Archive
    Last Post: 02-17-2005, 09:43 AM
  4. WTB - touchscreen friendly GPS software
    By 2.0i in forum Classified Archive
    Last Post: 01-19-2005, 03:49 PM
