Results 1 to 3 of 3
Thread: getting mappoint to work with earthmate & a cool gps program i found
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    1) Is there anyway to get the DeLorme Earthmate USB to work with MS MapPoint? Doesnt work because of NMEA compliancy.
    The error recieved is:
    "The GPS receiver is sending messages, but they are not being recognized as NMEA 2.0-compatible. Make sure the GPS receiver input/output format is set to deliver NMEA 2.0-compatible messages at the correct baud (4800 bps)."
    I have SA2003 also but Id like to see what MapPoint with AGPS can do
    2) I also found this relatively cool GPS program called GEM located here http://www.schaik.com/gps/gem/gem.html
    It uses online map system from Mapquest. Couldnt get it to work with my Earthmate though
    Sep 2000
    LA, CA, USA
    Wow that GEM program IS pretty cool... for those who don't have a full-featured GPS program. And the aerial photos are sweet.
    Oct 2001
    Ontario, Canada
    Earthmate is NMEA compatible, AFAIK (I had one, it worked fine with NMEA and S&T and a few other programs that require NMEA)
    "The NMEA output allows the Earthmate ™ GPS to be used with other software mapping programs"
    Oh, is your Earthmate the old one? Because apparently the new USB one is NMEA compatible
    http://www.delorme.com/earthmate/default.asp
    Otherwise you might find this page to be of great help
    http://www.gpss.co.uk/earthmat.htm
    GEM is also supposed to work directly with an earthmate, so I don't know why yours isn't.
    Good luck.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
