Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Cloud cover?
  1. #11
    Mar 2001
    I have my Garmin GPS35 in the rear window, which has a defroster/radio antenna. in fact, it's inside my rear window brake light (which is sitting on the rear deck, not at the top of the window), and I've never had any locking problems.. but then the Garmin GPS35 can lock from inside my metal trunk..
    Anyway, glad to h ear that repositioning it helped ya.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
  2. #12
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Wow, you just solved one of my problems. From the rear window to a side window. Now I get 3d lock, and can get routing directions. Excellent.
    4x4 in a turbo stylee.
  3. #13
    Jan 2003
    Ohio
    Ill have to move mine also then. It works ok in the back window, but notice it will jump back and forth between 2d and 3d
    Project K4RPU73R
    Via Epia-M 9000
    256MB PC2100
    40GB IBM Travelstar
    7" Xenarc
    DeLorme Earthmate GPS
  4. #14
    Constant Bitrate Suprapc's Avatar
    Apr 2003
    Scott, La
    Mine works in the back as long as it is far away from the glass (metalized tint + defroster strips) if it is like 10 in awy no problem but right up against it no go. I mounted mine external now so no problems at all.
    2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
  5. #15
    May 2002
    Warrington UK
    Mine (Deluo USB) was sitting on the rear shelf, roughly central and a good 12" away from the glass. No joy with a lock.
    Once I attaced it with double sided tape and velco to the side window instead. It locked no bother.
