Results 1 to 5 of 5
Thread: GlobalSAT BC-337 CF card GPS receiver.
    Jan 2012
    Hi guys, I have this which came with an old PCMCIA adapter, I'm trying to get it to work on my CarPC now and was curious if I buy a USB CF card reader would this work through that? I really want something with an external antenna port (which this has) as I'm trying to use a shark-fin style multi function antenna with it.
    Jan 2012
    Well, I ordered a cheap USB CF Card reader. I guess we'll see.
    http://www.amazon.com/gp/product/B004QHPYT0
    Jan 2012
    Well doesn't work with a CF card reader, apparently it's not a standard CF card type connection? Not sure why they would want to go that route though if it's not able to be used in a standard CF card slot? Anyways since it came with a PCMCIA adapter and I already own this GPS receiver from a while back (when I had a laptop with PCMCIA) I found that you can get a PCMCIA to PCI adapter pretty cheap. My case requires low profile cards and I've only found a couple of the adapters that are low profile. I could use a PCI extension cable and mount one of the standard cards to my case somewhere and cut a hole for the slot so that may be an option? Otherwise I may grab this dual card device and use it? I just don't like that it only take a portion of the card into the slot and not the whole thing so I'd have it sticking out of the back of the carPC.
    http://www.amazon.com/StarTech-com-P...0140724&sr=8-8
    Jan 2012
    Another option I just found is PCMCIA to IDE? I wonder if this would work?
    Edit: Meh I think I'll just try one of the PCI solutions.
    Jan 2012
    Ok, I bought a PCMCIA card that goes into a PCI slot and it works great for the GPS card. Also made up some adapter cables to attache my GPS and Wifi to the MP3car store multi antenna.
  1. FS: BU-353 GlobalSat GPS Receiver
    By fatejd in forum Classifieds
    Last Post: 05-16-2011, 08:02 PM
  2. FS: GlobalSat BU-353 USB Receiver
    By ZR5 in forum Classified Archive
    Last Post: 05-02-2006, 12:10 AM
  3. Globalsat BR-355 Serial GPS Receiver
    By aal2000 in forum GPS
    Last Post: 11-10-2005, 02:56 PM
