Results 1 to 10 of 15
Like Tree1Likes
Thread: GPS Lock Problems
    Feb 2003
    SE, PA
    GPS Lock Problems
    Ive had a carPC with GPS in my truck since 2002, so I am quite experienced in the subject
    but recently, my GPS will not lock regularly...sometimes it does, sometimes it doesn't.
    Im currently using a BU-353 that has been in service for almost 4 years. I thought maybe it was just old, so I got a new one (not a 353, but one a friend bought several years back but never implemented)
    same problem...
    nothing has changed in my system...same location, same hardware, same everything.....
    ideas?
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
    May 2013
    Melbourne, Australia
    I was disappointed with my BU-353 when first purchased, it wouldn't lock on, this was in terrible weather however. I found that I needed to drive to a sunny open sky to lock on and I've not had any further problems since.
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Does it happen everywhere, or only at home when you start the vehicle? Maybe something in the immediate environment is causing interference. Also less obvious stuff in the vehicle like a new smartphone or some other portable electronic device.
    Feb 2003
    SE, PA
    Anywhere, really.
    Sometimes the GPS locks, then just quits on me....to come back later..
    Sometimes the GPS will take HOURS to lock, other times it locks in under 1 minute.
    Same cell phone I've use for over a year.
    So strange!
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Hmmm...garlic cloves and Holy water perhaps?
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Just a thought, could be a connection or earth has changed in the Car PC installation. You could try checking every ground connection or plug the GPS into a laptop or borrow a stand alone GPS and see what happens to the GPS signal when you power UP/Down the Car PC.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Dec 2006
    istanbul
    Is the gps receiver connected to the pc through a hub? if yes, the hub may be the guilty one.
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    I have this same issue. Worked fine in my last car but here in my new car I have intermittent lock. Two days ago I was on the highway and going to my destination it worked fine. Coming back it kept loosing lock and think i was off the road. I don't know what's going on with this thing. W7 machine.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try having it on a meteal surface if possible.
    They have a backup battery, which after a while dies. This is used to store the last location so that when you start again it doesn't have to go search the whole sky again. There should be a thread on this issue. (although it was based on the older BU-3xx)
    May 2009
    Ladispoli, ROMA
    Try in the bios if you have the antispread and put they "on" in the cpu, ram and bus, I have had the same problem and now is all ok, when I turn on my pc the gps is ok
    chris350 likes this.
  1. GPS causes RR to lock up
    By Mustronic in forum Road Runner
    Last Post: 06-29-2010, 05:06 AM
  2. Cold weather lock up problems
    By theforce in forum General Hardware Discussion
    Last Post: 12-26-2008, 04:56 PM
  3. lock up
    By aco in forum Road Runner
    Last Post: 10-09-2005, 10:13 AM
  4. No Lock, WHY!?!?
    By nibix in forum GPS
    Last Post: 07-07-2004, 10:50 AM
  5. Not getting lock?
    By Misanthro in forum GPS
    Last Post: 12-23-2003, 02:21 PM
