Results 1 to 6 of 6
Thread: 5Hz Sirf IV from Mo-co-so
    Feb 2004
    MO-CO-SO is selling a 5Hz Sirf IV chipset usb receiver on Ebay. It's the only 5Hz Sirf IV unit I've seen. He doesn't even have it listed on his website.
    http://cgi.ebay.com/ws/eBayISAPI.dll...:X:AAQ:US:1123
    Item: 160939049093
    Is anyone familiar with this unit? I really want a 5Hz receiver to replace my BU-353, but the other options are using inferior chipsets. The one concern I have is the description says the following for update rate: "1Hz default, up to 5Hz". Can anyone decode that for me or clarify how you "switch" off the 1Hz rate to 5Hz? I tried contacting him, but didn't receive a response.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I would have a look at the sure development unit http://www.sureelectronics.net/goods.php?id=99 it has various connecton methods and comes with an external antenna. Very good unit fast accurate. Just a thought SNO
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Some GPS chipsets are read/write, meaning that you can send commands to the chipset to configure various operational parameters (like update rate). 1hz operation is typically associated with a 4800 bps connection, and that is the default NMEA 0183 standard. Keep on mind that the rate your GPS updates data has NOTHING to do with how fast your navigation program updates its position. That's entirely a function of the navigation software. Now many programs do support higher update speeds, but for instance, MS Streets and Trips doesn't. It only operates at 4800bps (1hz). Slower processors can also effect the ability of your system to redraw its screens.
    Bottom line is that you need to make sure all the pieces of your system can take advantage of the higher update rate.
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    The QSTAR BT-Q818XT I use can run at 1, 5 or 10hz.
    Garmin PC will accept 5hz data updates, Navigator free will run at 10hz.
    The biggest advantage I find with 5hz or 10hz updates comes when using the GPS for vehicle speed display as there is no lag in the indicated speed.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Feb 2004
    Quote Originally Posted by VegasGuy View Post
    What update rate does sygic fleet support?
    Aug 2010
    Bahrain
    1Hz AFAIK.
  1. sirf to nmea ! GPS
    By summer69guy in forum GPS
    Last Post: 07-30-2009, 02:00 PM
  2. SiRF or NMEA
    By TheUni in forum GPS
    Last Post: 09-16-2005, 06:40 AM
  3. SiRF!
    By Ninja Monkey in forum Map Monkey
    Last Post: 01-10-2005, 04:30 AM
  4. SIRF anyone?
    By grahamrb in forum Map Monkey
    Last Post: 11-21-2004, 06:59 PM
  5. BU-303 and SIrf
    By matty_g in forum GPS
    Last Post: 11-15-2004, 02:18 PM
