Results 1 to 10 of 19
Thread: Gps problem
    Mar 2011
    Gps problem
    Good afternoon guys, after a thousand trials with an antenna BT HOLUX model 236 and realizing that with every piece of software I have many problems, I would have decided to buy a new GPS antenna USB of course. The problem now is what to choose and I would be oriented on these 2 models:
    http://m.ebay.it/itm?itemId=170873233292
    http://www.telcominstrument.com/p_22...tellitare.html
    What would be more appropriate? I would like to have maximum fluidity in navigation, which with the antenna HOLUX was pure utopia. In fact, the navigation was very jerky and imprecise. I await advice on what to choose.
    BR
    Carlo
    Inviato dal mio Fantastico Samsung NOTE 3....altro che I-PHOGNE.... ahaha
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Carlo I would buy the sure electronics gps development board, http://www.sureelectronics.net/goods.php?id=99 It is usb as well and has an external antenna which can be mounted outside. It is the best unit out there right now as far as I am concerned. It's fast to lock, locks usually 9 or 10 sats runs at 9600 but can be changed to anything using their app. Good luck SNO
    Oct 2010
    Greece
    Sno what do you mean outside? Is it waterproof ?
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
    Nov 2009
    Keswick,On Canada
    The antenna is waterproof yes. SNO
    Mar 2011
    Quote Originally Posted by SNOtwistR View Post
    Wow. looks like a good product. you can also connect via COM port? in Italy it will be difficult to find. this site you reported is direct selling?
    Nov 2009
    Keswick,On Canada
    Yes they sell direct, you can connect via com port, bluetooth or usb. SNO
    Mar 2011
    Thanks a lot of info. just a little curiosity. do you think you can put the antenna inside the front dash? work? not a pretty sight to be put outside. thank you again. Carlo
    Nov 2009
    Keswick,On Canada
    Yes you can put under the dash as long as its plastic not metal and has a clear sightline to the sky. For the best gps reception it should be in the centre of a 3ft. diameter flat metal surface. SNO
    Oct 2010
    Greece
    @ Carlo . For best services go in ebay and find a seller named sureelectronics. he is an employe of sure electronics and his is faster and cheaper than their direct site....!
    Powered by M2 atx
    Mar 2011
    Thanks to all..
  1. Replies: 2
    Last Post: 03-31-2009, 11:43 AM
  2. DSATX problem, not power switch problem!
    By VThokieME in forum Power Supplies
    Last Post: 05-04-2008, 12:22 AM
  3. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 08:57 PM
  4. Sound Card Problem - READ FAQS and still problem
    By mbkowns in forum Car Audio
    Last Post: 09-17-2005, 03:20 AM
