Results 1 to 8 of 8
Thread: Alternative GPS Solution for OEM or ext. GPS antenna
    Sep 2012
    Germany - Munich
    Hi Guys
    I had an idea to replace my GPS Demoboard, because i like to try a smaller solution.
    And it is easy possible to increase the gps signal rate.
    before:
    after:
    first i replaced the small external gps antenna by a adapter cable, to connect an other ext. GPS antenna.
    after than i connected a usb to serial with the new gps board:
    +5V -> VCC
    GND -> GND
    TX -> RX
    RX -> TX
    I think it is also possible to connect a Bluetooth Serial Device.
    Good Result after first Test at Home :-)
    ebay items:
    380935100069 Ublox NEO6MV2 GPS-Modul
    380868454528 USB 2.0 to TTL UART 6 Pin CP2102 Serial Modul
    251560114438 Adapter Pigtail IPX / U.FL to SMA
    Oct 2010
    Greece
    except the problem you told about radio how is the new one related cold time and its signal ?
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
    Sep 2012
    Germany - Munich
    radioproblem exist any more
    maybe i have to put then board inside an iron case.
    don't tested the time. i think it's depended of used antenna.
    the boards has a backup battery, too.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I have over 50 of those dev boards in service just in a plastic project case. No problems at all with noise or interference the trucks they are in have a range of radios from am/fm/xm/cb and I have a separate gsm/gps/satellite tracker in there. Have you tried looking at other sources by chance? Just a thought SNO
    Sep 2012
    Germany - Munich
    Yes, i think it's a problem of my car installed radio antenna.
    but i don't have an other car to test with other result.
    Sep 2012
    Germany - Munich
    Nice Tutorial to change the refresh rate:
    May 2015
    Germany, near Potsdam
    @harryberlin
    I just build a CarPC for my Volvo XC90.
    Some parts I have found solutions, so to control the fronend I use the BWM iDrive cntroller as a HID Device.
    No I'm searching for a possibility to use the buildin GPS antenna of the car. It looks like that would be possible with
    the items you post above. Do I need some other items or only this 3 items? And will TMC work?
    thanks
    Sven_Lee
    Sep 2012
    Germany - Munich
    hi
    if your car istalled gps antenna is a usual gps antenna, you can connect with the neo board.
    you should find out wich plug you need to connect the antenna.
    tmc is not included. it's just a gps device.
  1. PSU choice?!
    By fxg in forum Power Supplies
    Last Post: 09-08-2011, 08:56 PM
  2. Connecting a Laptop Internal Antenna Cable to an External Antenna
    By sgtpepperaut in forum Wireless Communications
    Last Post: 09-28-2009, 03:21 PM
  3. Replies: 0
    Last Post: 03-07-2007, 10:31 AM
  4. OS of choice?
    By disasm in forum Software & Software Development
    Last Post: 05-22-2006, 11:31 AM
  5. HDD choice
    By MrSpace in forum Newbie
    Last Post: 07-07-2004, 06:16 PM
