Results 1 to 7 of 7
Thread: what com port is my Delorme USB on?
    May 2003
    i just got my delorme gps and it works fine and dandy with Street Atlas 2004, but when i try to run MS streets and Trip, the program cant find the GPS. I know this is USB, but the software only looks in my com ports. How do i trick the software into looking at my usb ports?
    And yes, i did install the drivers that came with the delorme CD.
    Variable Bitrate bjm2020's Avatar
    May 2003
    Louisiana
    Right Click My Computer and Click Manage. Go to Device Manager Then Click on Ports. When you installed the gps it should have set it to a Com Port.
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    May 2003
    theres 2 "Communications Ports" in device manager (1 and 2). But it doesnt say anything about the gps....
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    I think it depends on which USB port you plug it into. On my PC, it shows up on COM 4.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    mine has showed up on 3 and 5.
    '98 Explorer Sport
    80% done
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    If I remember correctly, there is a download from delorme to use USB to serial. Try that first. It may be included with SA2004, but for my SA2003, it was some download you had to get for other mapping software to reognize a COM port.
    May 2002
    Albany, NY
    mine came with a seperate driver cd you had to install. Also you had to make sure you selected the option to use it with other mapping apps. If you choose that it installed the usb to serial driver
    '98 Explorer Sport
    80% done
