GM is changing the onstar units to a digital ready unit instead of analog only as the older ones where.
Actually, I didn't buy the other Onstar receiver off Ebay it was Wayne Dohal. I didn't do a very good job of quoting him. I just ended up using an Earthmate with a serial cable. If I ever tear into the dash again I'll take a look at the Onstar unit to see if it is the newer design.Originally Posted by openminds
2002 Oldsmobile Alero GL2 4DR
Aleroputer 90% done (ripped out and being rewired)
MYMODS:
Pioneer Head unit in a remote location, Clarion Amp, XM Satilite Radio, 2 10" Audiobahn DVC Subs wired 1 ohm in a bandpass box, Grill Mesh, Halo Guages
Hey openminds, do you have some info available on the Sony GPS chip???
I did so much to get my Avalanche ready for this mod, only to be crushed by having the damn sony chip..
Thought I'd drag this to the top.
First: props to openminds for coming up with this. This is an awesome idea.
Second: props to all the folks helping with my particluar challange over at Saabcentral.com.
Together, we're going to get this working in a 2003 Saab 9-3.
Anyway, what we've determined so far is that there is a Sony chip in there. Specifically a GXB3000 using a CXD2932 chip.
The pinouts are way different than what you have, but that is to be expected. My biggest hurdle is that I cannot find ANY info on the GXB3000 ANYWHERE. There is loads on the GXB2000 ( http://products.sel.sony.com/semi/PDF/GXB2000.pdf ), and they are similar. I can only hope the pinouts are the same.
Does anyone know where to find a spec sheet for the GXB3000?
Anyway, I have a 10 pin connector (all in 1 row), and have to determine which is pin 1. After that, and I scrape some dough for the RS232-to-TTL Serial Level Converter, I'll be in business.
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
