Nevermind found it
http://www.globalsat.com.tw/english/...n_id=5&p_id=12
So yep looks like its the opposite way around then, Doh!
Hmm, you maybe right but that's the opposite way around to the Haicom USB GPS devices as they are:
LED OFF: No Power
LED Flashing: No fix, searching
LED Solid: Fixed
Anyone know what actual model that is rather than just the chipset type![]()
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
Nevermind found it
No, mind is:
LED OFF: Receiver switch off
LED ON : No fixed, Signal searching
LED Flashing: Position Fixed
So probably depends on the GPS Receiver manufacturer.
Mine is a Holux GM-210
unsavory,
Yes that exactly what I meant.
Its seems to vary between manufacturers and hence the doh was coz I was can't believe I didn't realise this earlier![]()
OK I guess I'm the stupid one. Yes, the little LED means the gps has acquired enough sats to compute the fix. Sorry. Seeing the word "fix" took me back to my days as a Naval Aviator and I confused it with a position displayed on a map (actually we used charts).
I can see now how he had a "fix" even with the PC off, assuming he used a powered usb hub.
Hi, thanks for replyin, sorry bit slow on getting bak to you all,
ehm yeh the gps device still gets power even when my epia motherboard is turned off, stupid opus obviously doesn't cut the power completely, yeh but when the pc is off the gps starts to flash which means by the readme that the gps has a fix, solid means searching.
I know this to be true because i was using it with my laptop in the car the otherday working fine for bout 1/2 hour and the gps was flashing indicating it had a fix which it had because of autoroute working.
Hi, after windows does that wee scroll thingy at the boot screen and goes to the black screen with the mouse pointer(just before the welcome screen), it is then when the LED goes solid, i have auto route installed, but does not launch automatically, and that testinfo.exe prog doesn't start automatically not that i know, but nothing can be using it when it starts because if i go and run say autoroute 1st it can access it, so obviously nothing else must be accessing it?? dunno?
Unless autoroute has some driver or something it loads with windows?
Im probably best trying some other gps nav thing, any recomendations, live in uk mind, so was thinking destinator?
Any more help would be very much appreciated
Thanks Again
Just a note that I have the same "puck" GPS as yours, connected to an M10000 motherboard, and I have exactly the same symptoms as yours.
I at first though that the GPS might just be blinking at startup to say "not initialized". However, right after I power-on the system, the LED is solid, then about forty-five seconds later it starts blinking (which is about the amount of time that it is advertised to take to get a fix from a cold start). Then I get the "Windows Starting" screen about ten seconds later, and the LED goes back to solid.
If I go into the GPSInfo program that ships with the unit, it shows that it sees 12 satellites, but they are all red, which means that there is no fix. If I hit "Cold Start", I only see one red satellite from then on.
I uninstalled the drivers and restarted, but had the same symptoms, so it seems like the generic USB is doing it, not something specific to the drivers.
I'm thining of installing Linux on the hard drive, just to see whether *its* USB initilization would have the same symptom, but that is a lot of work.
Any help would be greatly appreciated! It sounds like a lot of people are using the same receiver (I bought it based on recommendations from this forum). Other than myself and the original poster, is anyone else having any problems. Of those who are using it successfully, what is your system configuration?
Jason
I have the BU-303 GPS mouse and am experiencing the same f*in problems. Win2k...m10000 board...arg!
have you guys tested with the GPS outside of the car. you may need to take into account the fact that the car and its decorations (tint for the windows) may be acting as a perfect shield that prevents the GPS device from receiving anything.
I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
NavSys, the ultimate navigation app
http://www.navsys.org/
