Results 1 to 3 of 3
Thread: GPS Antenna with RG174 cable
    Dec 2003
    SLC, UT
    I found a GPS antenna that has a 5M RG174 cable for connection. Would something like this work for a PC based GPS? If so, what type of hardware is needed to support the RG174 cable input?
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    a soldering iron and some patience
    car computer rev 5: 8" lilliput and usual suspects
    Jul 2002
    Maybe all you're looking at is an external antenna to connect to a GPS unit, which won't get you very far. RG174 is just a coax cable for RF signals. If thats the only connection, it doesn't sound like you're looking at a complete GPS.
    The GPS units I'm aware of have RS-232 or USB connections for the PC (and maybe a power connection), or a connector like an RJ45 on the Garmin GPS-16 I have which required me to build an interface cable to hook it to the com port on the PC. A GPS unit designed for a separate antenna might use RG174 as the cable between the GPS electronics and the antenna.
  1. external gps and aprs vehicle tracking
    By swingwally in forum GPS
    Last Post: 10-23-2004, 03:33 PM
  2. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  3. Replies: 4
    Last Post: 09-04-2003, 10:20 AM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
  5. Cat6 cable -> IDE Cable
    By dan0myte in forum General Hardware Discussion
    Last Post: 08-31-2001, 09:29 AM
