Results 1 to 9 of 9
Thread: iGuidance splash/disclaimer window
    Sep 2003
    Northeast Ohio
    Does any one know how to disable/bypass the annoying splash/disclaimer startup window in iGuidance?
    System:
    Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
    Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    Quote Originally Posted by UncleGeek
    I use a keyboard macro/hotkey, that does the CTRL+ALT+H for the routis shortcut on the desktop (edit the shortcut settings to accept a hotkey), and then it presses enter after .5 seconds for you.
    I use the speedpad from belkin to do this, but I'm sure there are macro programs you can use for a normal keyboard.
    You can also modify the popup screen to be tiny, and have no text, but I can't figure out a way to automatically return an OK or even bypass that routine completely. It's all in the routis.exe file, so there is no INI file to mess with afaik. I believe it's programmed in Visual C++.
    Interestingly, I can replace all the buttons and some of the menus with colors and shapes of my choice, but I think I like the standard colors even though they look like fisher-price stuff
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
    Sep 2003
    Northeast Ohio
    Vineet,
    Thanks for the info!
    System:
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    We need to contact iGuidance and have them give us an option to remove this..
    www.i-hacked.com Hardware hacking articles
    FLAC Chairboy's Avatar
    Jan 2004
    I noticed this on Frodo's website:
    RoutisLauncher 1.0
    Description: Launches Routis and clicks OK on the warning window.
    http://www.frodoplayer.com/frodosuite.htm
    Dunno if it works w/ iGuidance, but I've read that they're both basically the same. No personal experience.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Constant Bitrate reggiek945's Avatar
    Apr 2003
    Oklahoma
    Try this file file from this post, it worked for me. I'm using iguidance 2.0
    routis splash/startup screen
    Jul 2004
    Quote Originally Posted by reggiek945
    Yeah, what he said! I used iguidancelaunch with the instructions from post #68 and it works like a charm.
    Jun 2000
    NYC
    yeh. what he said.
    Variable Bitrate egeekial's Avatar
    May 2004
    oh, what the hell... yep, works for me, too
  1. Replies: 5
    Last Post: 01-19-2004, 01:57 PM
  2. LCD in rear window
    By ryanerb in forum LCD/Display
    Last Post: 11-21-2003, 09:45 AM
  3. Replies: 0
    Last Post: 08-28-2002, 05:23 PM
  4. pics of my pioneer slot DVD window mod =)
    By moahdib in forum General Hardware Discussion
    Last Post: 04-30-2002, 06:10 PM
  5. Pioneer Slot DVD plexi window mod
    Last Post: 01-24-2002, 01:55 AM
