Results 1 to 10 of 14
Thread: GPS for under £70.00
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I have just bought a Fortuna GPS Serial from here I have stuck it inside the enclosed mdf case with the PC, and it works 100%.. finds the sats in under 60sec's.. I went for the serial version as after reading these forums it seems they have a better chance of working with more software.. So it seems you dont even need to glue it to your window :-)
    Steve
    Raw Wave
    Jun 2003
    That look like a good GPS, cheap too. I keep thinking if its as good as garmin GPS16...probably better.
    Can you keep a lock inside a tunnel?
    Feb 2004
    Manchester
    dont know, I havent been to far in it yet, but there isnt any tunnels round here.. I wouldnt expect any to keep a lock in a tunnel
    Feb 2004
    Thumbs up
    I use the USB version of this reciever under WinXP and with InfoMap Navigator and Route66, no problems at all. Luckily I have a sunroof on the Vectra so I have no problem with placement.
    Going through tunnels will result in loss of satellite signals (duh!) but since the GPS reciever is warm and have a position that is (usually) very close to the one it gets upon exiting from the tunnel, this is no problem, it picks up the cars position almost instantaneously.
    Under the roof of a gas station the other day I even picked up 4 satellites.
    Raw Wave
    Jun 2003
    Going through tunnels will result in loss of satellite signals (duh!) who said that?
    Thats not true m8, what receiver have you tried? you obviously never owned a decent one.
    Im using garmin GPS16 and have tried it in rotherhite and blackwall tunnel in london, both are 3/4 - 1 mile long. The GPS can keep the lock with no problems, Although it looses the heading and position accuracy when I reach the middle of the tunnel but it carried on working. How do you explain that? If it did lose the signals it relock within seconds.
    The reason why I asked because I used to use the SONY (ETAK GPS1) and losses lock once I pass slowly under a railway bridge thats only 10m wide or so, then another few minutes before it relock...what a piece of crap. Tried TomTom bluetooth GPS and some other brand on my Ipaq PDA, not impressive at all.
    I get 7-9 on mine.
    Garmin GPS16 cost about £130-150 against a £70 GPS. It may be good thats why I asked how well it peform and garmin is probably just over priced, ripping us off. Garmin GPS18 is out soon with the same spec as GPS16 I dont know how well it perform in real life though.
    Check it out here :
    http://www.gpscity.com/gps/brados/15.../oem18usb.html
    Yes its only $84.95 = £45.64 even if you have to pay postage and taxes it is still cheap cosidering you have a better receiver. Exchange rate is good, so its best to buy in USD.
    Sorry CdRsKuLL Im not trying to put down the fortuna, just trying to compare how well it perform against the others. Shame you dont have tunnel there to test it.
    Whenever I buy a new GPS, first thing I do is drive through the 2 tunnels we have in here
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by Ricky327
    Whenever I buy a new GPS, first thing I do is drive through the 2 tunnels we have in here.
    I find I rarely get lost in tunnels, although there is a maze forming under Boston now so who knows! I think any GPS would do well to get throught he big dig tunnels.
    As a GPS needs a clear view of the skies I asssume anything that "works in a tunnel" is at best estimating, or just not giving up as fast as other GPS units? I don't see how it could actually work underground.
    Chris.
    Raw Wave
    Jun 2003
    Apparently theres a new supersensitive GPS :
    http://www.eetuk.com/tech/news/dev/OEG20031128S0004
    Theres another article about this new technology somewhere on the net...I cant find it again
    Raw Wave
    Jun 2003
    I find I rarely get lost in tunnels, although there is a maze forming under Boston now so who knows! true
    I got lost when I was under a tunnel in norway, with my crappy GPS as soon as a exit the tunnel it cant lock until I traveled a few miles. I do find it amazing how it can keep the lock under a tunnel...I had some experience where Im in the city with lots of building on a narrow road, I had problem with accuracy driving there.
    Mar 2003
    Basingstoke, Hants
    That's just not possible! GPS is line of sight. If it can't see the satellites it can't calculate the position.
    Ok heres the science bit
    Satellites are equipped with very precise clocks that keep accurate time to within three nanoseconds - that's 0.000000003, or three billionths, of a second. This precision timing is important because the receiver must determine exactly how long it takes for signals to travel from each GPS satellite and therefore the distance to the satellite. The receiver uses this information to calculate its position.
    When you go into a tunnel you WILL lose the signal. The first thing you will lose is altitude. Most GPS can keep calculating the position using just 3 satellites, some can approximate it using 2. Speed is calculated as the distance travelled between 2 fixes.
    Raw Wave
    Jun 2003
    Yes I know in theory it not supposed to work and I do believe the theory.
    But from my experience with GPS16 it does work, I dont know why. I drove through the tunnel many times and still show the possiton correctly just maybe 5m off. On different day it sometimes looses the lock, but the point is it carried on working most of the time
    I am indeed amazed why this is so.
  1. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  2. Cant get good GPS signal in car.
    By Ricky327 in forum GPS
    Last Post: 01-29-2004, 10:28 PM
  3. GPS software
    By waylonh in forum Input Devices
    Last Post: 11-25-2003, 07:48 AM
  4. Replies: 4
    Last Post: 09-04-2003, 10:20 AM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 03:26 AM
