Results 1 to 9 of 9
Thread: garmin 18 vs 16
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    garmin 18 vs 16
    Which one is better the garmin 18 or the soon to be released 16?
    Thanks.
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    I think you mean 18 b/c 16 has been out for almost 2 years. If I had to do it all over again, I would get the GPS16A as it updates its position 5 times a second opose to once a second like the 16 or the 18.
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    Do we really mind having 5 updates per seconds for our car??
    -Mars
    Raw Wave
    Jun 2003
    Yes Ill go for GPS16A...at the moment I have GPS16 and the update is 1 per sec.
    Heres a scenario why I want GPS16A :
    In UK we have many roundabouts, big one and many small ones. You can easily miss the turning if you are not paying attention to your car PC. Yes I know it tell you which exit to take but once you missed it the software then recalculate...this cause alot of confusion on the software and you. The software doeasnt tell you which exit to take anymore as it lost count from where you are...you are also confused. Now trying to work out which exit to take, keeping your eye on the screen and at the same time driving in a busy roundabout can be dangerous. As you kept missing the exit the software then keep recalculating the route. In the end you keep going around in the circle until you felt it is the right exit. I tell you, most of the time its the wrong exit Ill take ... not funny when you enter a motorway
    So a real time display is very helpful with this roundabout thing with smooth map scrolling.
    Im not too sure what software support many times per sec update. I know the autoroute/mappoint can only display 1 per sec.
    Anyone one know that may support GPS16A?
    Dec 2003
    Pasadena, CA USA
    I was going to order the 18 till they updated their site and it says that it will only work with Garmin's Mapsource software.
    http://www.gpscity.com/gps/brados/15.../oem18usb.html
    Sometimes, always, never ....
    Feb 2004
    Honolulu, HI
    Quote Originally Posted by Harry5150
    the garmin 18 usb version outputs to garmin proprietary format, but the bare wire version and the pc (serial) output to NMEA 0183 data format, but may also be user programmed to output data in the GARMIN proprietary format.
    http://www.garmin.com/products/gps18/
    Can someone decipher the technical specs between the 16 and 18. I don't really care for the 5 updates a sec. 1 update a second is plenty enough for me. But the 16 costs ~$200 and the 18 is gonna cost ~$85 so I wanted to know why the big price difference, obviously I don't the 18 if it's gonna be a POS.
    Aug 2002
    Studmon3y: You obviously never used or had a GPS setup before. 1 second update seems fast enough but in reality, it's not. Most factory navs update at least twice a second. Granted the software must also support fast update but once you got the hardware, you can always update the software later. When I built my system I spared no expense and got the best at the time. Unfortunately I was limited to choose a GPS receiver with 1 second update rate. If I had to do it over again, I would get the GPS16A. You posted here asking for advice from someone who has experience in GPS. I am here telling you what to look for in a GPS. If cost is the main concern, then get the GPS18. Garmin makes good GPS receivers. You cant go wrong with Garmin.
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Does the Garmin GPS16A come in black? If not, is it ok to paint it?
    Feb 2004
    North Aurora, IL
    Quote Originally Posted by wysocki
    id also like to know if you could paint the garmin. if so, what type of paint would i need?
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  3. WTB: (or trade) 8" 18 bit touchscreen
    By SuperMatty in forum Classified Archive
    Last Post: 04-11-2003, 12:08 PM
  4. Garmin 35 PC USB VS. Deluo USB Receiver
    By SLAYER6669 in forum GPS
    Last Post: 10-03-2002, 01:33 AM
  5. Does 18 conductor printer cable work for LCDs?
    By LESLIEx317537 in forum LCD/Display
    Last Post: 02-11-2002, 12:03 PM
