Results 1 to 5 of 5
Thread: RAND McNally and Map Point 2004 - anyone got it working?
    Jan 2004
    Hi all, I am having a small issue,
    I have hooked up my gps to the pc and using Hyperterminal i am able to read NMEA sentences just fine, everything works.
    when i hook it up to Map point 2004, it says "Initializing" and it never finds the current location,
    Map Point states that the gps reciever must be NMEA 2.0 compatible and i did check the reciever specs, it says its NMEA 2.0 compatible.
    i am just wondering waht i am doing wrong.
    i do no thave any other software other than map point to test it
    if anyone had issues, assistance would be appreciate it
    Kovan,
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    How do you connect the gps to the pc - is it usb or serial? If usb, do you have a usb-serial driver that makes it appear on a comport? Mappoint needs to see the gps on a comport.
    Jan 2004
    Quote Originally Posted by wi77iam
    the gps is serial,
    and yes the map point sees the port because when i go to "configure GPS" it lists the port the gps is on, so it has no problem detecting that there is a communication port that is avaialbe (and only shows it if gps is connected)
    the problem is that map point is not getting the signals
    Oct 2003
    Exclamation Did you change it to NMEA on your GPS unit?
    Quote Originally Posted by kovan
    the gps is serial,
    I notice you have been configuring your software over and over, have you actually configured your GPS to send out NMEA instead of whatever the default is? Example: My Garmin by default is NOT NMEA, it is a Garmin protocal. so it only works with my Garmin Map Source CD's I purchased.
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by yuprules
    What do the strings look like in HyperTerminal?
    I've found MapPoint to be fairly picky, it likes a very good lock before it is happy to show position. Did your GPS come with any test program? Mine (Deluo) has a test app, I guess it should be generic, you might want to grab it from their web site and try it.
    You did close down HyperTerminal I assume... apps don't like to share serial data.
    Chris.
  1. Need good GPS software for Canada
    By Bobby Digital in forum GPS
    Last Post: 02-11-2004, 07:45 PM
  2. Navtech maps for Canada
    By greenglo in forum GPS
    Last Post: 02-04-2004, 11:29 AM
  3. Map Point
    By Striker169 in forum GPS
    Last Post: 10-29-2003, 12:01 PM
