It's all about mathematics. You're probably only getting 2 or 3 satellites tracked which will be enough for the GPS to calculate lat/long but not altitude. You'll need at least 4 satellites for that.Originally Posted by shadowpuck
Just curious if this is normal for GPS or if there's a setting or hack I need to apply.
I just installed a Rayming TN-200 mouse and I'm using Mappoint 2004 with it. Just sitting here in my living room, the unit is tracking perfectly but the altitude is fluctuating quite a bit. I'm not really interested in altitude, just curious if that's normal for these things....
This item is the first step in my carputer project - I'll keep everyone updated!
Interesting - thanks for the info....Originally Posted by Falken
I wonder if there's some way to see the status of the receiver...I suspect there is somewhere.....
Sure, There's a number of them available. Try this one.Originally Posted by shadowpuck
Doug
That did the trick - as you stated, I wasn't seeing the third satellite. I moved the receiver around and noted different results....Originally Posted by Falken
Thanks again for the info!
