Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: GPS Through Metal?
    Feb 2004
    Menlo Park, CA
    GPS Through Metal?
    Hey all, I'm looking to get a NMEA compliant GPS reciver. However I'm not sure which to get. It would be nice if it was accurate and would work efficiently though my metal roof. Any suggestions?
    2003 Subaru Impreza TS
    Staus: Done.. too lazy to make pictures lol.
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    wont work. It'll take forever to lock. Hell, most GPS receivers wont lock even under tinted windows.
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
    Constant Bitrate NUIpIsqo's Avatar
    Aug 2003
    Bay Area (Fremont), CA
    Quote Originally Posted by cproaudio
    ha, i swear, we all met today, but it takes a board to answer this question. it just shows that there just isn't enough time to exchange every idea on our minds.
    52-hit-combo?! Is that really necessary?
    Mar 2003
    Basingstoke, Hants
    Quote Originally Posted by Maeveth
    Hi, I sell a vehicle tracker which, as an option, comes with a high gain GPS. The manufacturers say this is for covert installations of the unit and GPS and works through metal skins but only updates every 15 seconds. I was rather surprised to see it's a Fortuna U2. No idea why it should be any more sensitive but that's what the tracker manufacturers say.
    Doug
    Nov 2003
    Denmark
    Quote Originally Posted by Falken
    Doug
    Your supplier could sell sand in the saharah dessert if he is able to convince buyers that his high gain antenna works through the metal skin.....
    Come on wake up, the GPS signal link margin is very low (signal is only -130dBm) and therefore very sensitive to any attenuation. What he might mean is that his high gain antenna will help the gps receiver to receive multipathes/reflection and this way operate without clear skyview. This does not mean that you can put it in a place where it is totally surrounded by metal.
    High gain antenna are normally used for application where in-door operation is wanted, but high gain antenna's are also more directive and therefore not necessary better for GPS since you need minimum 4 satellites for 3D or 3 satellites for 2D fix.
    GPS modules that claims that their module works in-door normally means that you need the first fix outdoor or close to a window, and then you would be able to move "longer" away from a clear skyview. The reason that the GPS receiver needs to be outdoor or close to the windows initially is following: A gps good receiver normally needs C/No of 36-38 dBc/Hz for acqusition (initially) and only needs a C/No of 26-28 dBc/Hz for tracking.
    BUT there is a price to pay, navigation on multipathes/reflections results in higher DOP (Dilution of precision) and thereby a worse position accuracy.
    /ProCos.
    Feb 2004
    Menlo Park, CA
    Quote Originally Posted by NUIpIsqo
    Actually I think that meeting gave us without setups more to think about and more questions to ask. Before yesterday I would have never considered that GPS doesnt work through metal. 8 )
    May 2002
    there's no way this will work. you need to have the antenna mounted *outside* the vehicle. period... (sorry about that )
    of course, you can use a separate antenna and calculator, with the antenna outside, and the calculator inside. but the antenna MUST be inside^W (oops) outside.
    I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
    NavSys, the ultimate navigation app
    http://www.navsys.org/
    Jan 2004
    Quote Originally Posted by sxpert
    That is not correct. Mine is inside and it works perfectly fine. It is, however, underneath the front windshield.
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    but the antenna MUST be inside.
    Covers all the bases..!
    Mine is inside too, on the dash, works great.
    Mar 2004
    San Diego
    The satelites are 15,000 miles above the earth and the signal is very weak by the time it gets to your receiver. I don't care what kind of high gain antenna you use- you will still need a view of the sky and it is NOT going to work through metal. That's why lojack and now Boomerang Tracking are so successful- they don't use GPS for tracking the stolen vehicles. Cellular and digital signals have much better in-building penetration. Are you saying that your GPS will still work once they roll your Porsche into a shipping container? Nah- I didn't think so.
  1. external gps and aprs vehicle tracking
    By swingwally in forum GPS
    Last Post: 10-23-2004, 03:33 PM
  2. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  3. Cant get good GPS signal in car.
    By Ricky327 in forum GPS
    Last Post: 01-29-2004, 10:28 PM
  4. Replies: 4
    Last Post: 09-04-2003, 10:20 AM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 03:26 AM
