I tried it and found it too small and fiddly for touchscreen, unless you have a 15" touchscreenOriginally Posted by chenko
Been looking around for PC based GPS navigation software, and InfoMap from reviews looks good, and is cheap... but something that im worried about is how touchscreen friendly it is? small icons, etc etc...
Does anyone use this? is it easily customized ?
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
Hi There,Originally Posted by chenko
First of all I'm declaring an interest as I sell Navigator.
Navigator is a Windows development of Infomap Routefinder. Becuase of this the icons are tiny and really aren't very easy to operate from a touchscreen.(I use a Lilliput). Having said that, You very rarely use them!
I turn the pc on, start Navigator and the virtual keyboard (really must get round to putting them in the startup folder). One of the irritating things about Navigator is the need to start GPS tracking manually. One you've done that everything else works fine with a touchscreen. Touch postcode or search, using the virtual keyboard key in the postcode or address you want. touch find. That'll give you a list of the matching results. touch the one you want, right touch it and touch "set navigation destination". One last touch and you're up and running. From there on the automatic recalc, visual and voice directions, head-up maps keep you on track without needing to use the touchscreen or keyboard/mouse.
It actually took me longer to type it in here that it did to do it!
It does have some customisation capability. Colours, fonts, what appears at what scale etc etc but there's no skinning or ability to add buttons. There is a professional version that has an ActiveX interface so you could develop your own! I've seen some of the development and there's some good stuff coming along. The one I really want to see is the touchscreen control panel which will answer most criticisms of it.
Navigator isn't the best, but for value for money it takes some beating.
Doug
Any linkage or more info on Navigator?
/edit
mmm, acctually, I was talking about InfoMap Navigator
The GPS autostart has never phased me, I can do that myself by sending the routine to the application via API, easy enough.
Other than the ActiveX, what advantages does it have over the standard ed? (@£35)
/edit
ah, GPS bundle, I've already got the GPS unit .![]()
Does everything that the standard edition does but also import databases on the mapOriginally Posted by chenko
step by step wizard to guide you through the import process
Import data bay postcode or geographical coordinates (latitude/longitude, British National Grid, Ordnance Survey Grid)
Represent data as icons and text labels
ActiveX control works with Visual Basic 6 and .NET, Visual C++ 5 and .NET, Delphi etc
Integtrate maps into your own programs
4 COM objects - map, user objects, database search and routing
add icons, polygons, lines, tracks and text to the map
find nearest function (for finding the nearest street, town etc)
convert between coordinates (lat/long and British National Grid)
postcode search with grid references (optional)
Regards
Doug
simaCar from a Dänish company is fitting perfectley for touchscreens
see www.simatech.dk
I've seen that about before, and there is no things as costs etc, and not much info either.
I will start reselling the software. The price depends on the Map data:
For example: GB + Europe Main roads 430 Euro + Tax
You can get a Demo as well.
Some Features:
- Focus on Touchscreen with Onscreen keyboard
- Naviagtion with Voice (Arrows and/or Map)
- Easy to use
- Searching for Streets, nr, city or postcode
- Favorites
- excellent Map data (coming from Teleatlas)
