Results 1 to 5 of 5
Thread: Navigator - Turn By Turn for Victoria(Aus) Trial (I got it)
    Feb 2004
    Australia/Norway
    I got the Navigator Turn By Turn trial today and I can’t say that I am very impressed how the software works with my setup. First of all the program takes incredible amount if resources (Cpu and RAM) so it is slow as hell on my system.
    The copilot voice is great but it is too slow. It tells you to turn left 10 seconds after you were supposed to turn left so you can’t really trust what the software tells you to do. Then you would miss all the turns .
    The software updates too slow, when you drive in a street the software shows that you are 100-200 meters behind on what you actually are, but when you slow down or stop the software “catches” up with you again.
    If you do take the wrong turn the software tries to recalculate a new route, but it takes 3-4 minutes before it does so and when you are off the original route the voice stops so you have to follow the arrows and directions on the screen instead.
    I am using the USB GPS mouse and I have good “signal” to 5-6 satellites when I am driving around.
    512 MB RAM, 1 GHz on MII 10000 motherboard on a fresh install of Windows XP PRO.
    Sorry for my bad English
    Apr 2003
    Melbourne/Cranbourne
    oh this is not good. What is the interface like, is it easy to use? Would you need a vga screen or would it work fine on a composite?
    CarPC: Currently in progress...
    Feb 2004
    Quote Originally Posted by aphesis
    The interface is not that bad. Its basically just melways with GPS support added .
    There is a small screen popping up with the arrows for directions and speed etc when for copilot and directions.
    I am not sure how this would look like on a none VGA screen but I think it would be okay since you dont need to look at the screen for directions.
    Variable Bitrate Freeman's Avatar
    Aug 2003
    Australia
    damn, i found out with mapsource that if u zoom in and out a bit the detail comes back
    just a little trick to try for us with gps mouses
    It aint no family car.
    SEE MK2 At : -
    http://www.mp3car.com/vbulletin/showthread.php?t=22810
    Feb 2004
    Quote Originally Posted by Freeman
    Why dont you use MapSend ? Full details all the time
  1. Remote turn on: 2 Amps + EQ
    By jspeeder9 in forum Power Supplies
    Last Post: 10-20-2003, 02:07 AM
  2. 6" eartLCD won't turn on anymore!
    By psuter in forum LCD/Display
    Last Post: 07-18-2003, 02:47 PM
  3. Inverter users, how do you turn it off?
    By phoTToniq in forum Power Supplies
    Last Post: 03-29-2003, 03:26 PM
  4. Replies: 0
    Last Post: 07-23-2002, 12:45 AM
  5. Replies: 2
    Last Post: 01-26-2002, 05:53 PM
