Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: GPS Speedometer?
    Apr 2003
    Melbourne/Cranbourne
    GPS Speedometer?
    Hi,
    Well at the moment the speedometer in my dash doesnt seem to be working and seeing that I have a gps and car pc I was wondering if there was any standalone programs out there that would give me a speedometer?
    CarPC: Currently in progress...
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    SEARCH!!! There's a lot of topics on this!
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
    Apr 2003
    alright just searched through over 10 pages of search results and didn't find what i was looking for. Mind telling me what the program is called?
    Aug 2003
    Michigan
    don't know of any standalones off hand, but I know that Street Atlas 2004 gives you your speed.
    so that means I'm sure you can get one.. if not, get street atlas
    you really should get that thing fixed.. or actually not. then you get 1 get-out-of-speeding-ticket free card.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    Jun 2003
    Memphis - TN
    I asked the same question a while back regardi ng the same issue.
    I emailed him and here was his reponse.
    The speed info is sent in the nmea stream you get from your GPS reciever.
    Its pretty much just one type of stream that gives you that info.
    It will look something like this
    $GPRMC,224043.051,A,5152.435,N,00159.5732,W,000.0, 238.8,190603,003.7,W*6C
    so the 7th or 8th value is the speed in knotts, which in this example is
    000.0.
    So the conversion to change knotts to mph is
    000.0 * 1.151
    From what I've seen with just dumping the nmea stream you only get 3 types
    of strings coming in. At least from my reciever.
    $GPRMC
    $GPGSV
    $GPGGA
    There are a few websites out there that'll tell you everything about the
    streams you'd ever want to know. So pretty much the reciever does all the
    work, you just have to grab the right string and get the value and do the
    math.
    Mike
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Constant Bitrate GRUNT's Avatar
    Sep 2002
    Scotland
    I have a speedometer running on my test software, uses $GPRMC data.
    Give me some time, I will cut out the code and build a standalone Speedo.
    If you have a graphic if the Speedo dial, and resolution you want to use.
    PM me the graphic.
    I can only try!!
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Talking
    Ok, let me get this straight, your speedometer which works off the basic principal of counting how fast your wheels are spinning isn't working so instead of fixing it your gonna rely on a multi billion dollar system of satellites and calculations the must be performed thousands of time a second just to get a speed approximation that isn't anywhere near as accurate... this sound's like a government project to me.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Oct 2003
    Toronto, Canada
    Speedometers lie!!@ GPS doesnt! (Well it does, but its because of the government!)
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    FLAC Chairboy's Avatar
    Jan 2004
    While GPS doesn't update anywhere near as fast as your speedometer, it's a far more accurate indicator of your speed then the speedo on your dash. Speedometers have inaccuracies introduced by everything from tire wear to deliberate overreporting to reduce car accidents.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    the only reason I think hes doing it, is because he CAN.. lol and thats without doubt the best reason anyone can have. :-)
    Steve
  1. Replies: 17
    Last Post: 02-19-2007, 05:21 PM
  2. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  3. Cant get good GPS signal in car.
    By Ricky327 in forum GPS
    Last Post: 01-29-2004, 10:28 PM
  4. Replies: 4
    Last Post: 09-04-2003, 10:20 AM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 03:26 AM
