can you post the solution? I'm still stuck looking at my 7" monitor, and can't figure it out. (and I'm lazy)
I was wondering if there is a way, in SA2004, after using the radar feature to find a location to set that location as your destination. seems like it should be there, but the closest i've come is clicking the directions tab, where it gives you directions.
as far as i can tell it doesnt even give you an address to cut/paste into the route feature.
[EDIT] Found it. installed it on my home PC.. where I could actually read the options -- (much harder on 7" composite)
pleaes disregard.
VIA EPIA 533 MHz
256 MB RAM
7" Lilliput VGA Touchscreen
20 gig HD
Media Engine 2.1.4
GPS - Earthmate/SA2004
802.11b Connectivity
