Results 1 to 10 of 11
Thread: Serial GPS unit, does it use pin 8?
    Oct 2003
    Vancouver, BC
    The motherboard I bought only has one serial port, is it possible to have the serial GPS unit plugged in and solder the 5V line from the power supply to pin 8 so I can use that as a shut down controller? I'm eventually going to use a USB gps unit, just curious of it would work or not.
    Blackpool, UK
    yeh that such work, as long as u dont need dts/rts handshaking, which u dont on gpses usually, they just send blind. infact all you need is the rx line from the gps serial, the other pins on the serial port can be used for other input/output. make sure the app your running for gps output doesnt use the other pins mind, if so you might need to write a simple app that creates a virtual com port for your gps app to access, and your app will just write whatever it sees on the serial rx line to your virtual comport, and ignore any writes to the virtual comport from ur gps app.
    hope that helps
    regards
    matt brocklehurst
    Website: www.carpcshop.com
    Email: matt.brocklehurst@terrastudios.net
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by LittleDragon
    Windows will only allow one app to control the com port, so I don't see this working...If you're using Windows
    5v line to pin 8, how does that work?
    Oct 2003
    Vancouver, BC
    Quote Originally Posted by Laidback
    just relay it with the ignition and setup a UPS. When you turn off the key, it'll cut power to pin 8 which makes windows think the UPS lost power and proceeds to shut down.
    Oct 2003
    Madrid
    Ok, I thought you may have meant through a relay, that's how mine works....but Windows won't let you put both the USP service and another program (GPS) on the same com port.
    Mar 2004
    thats not entirely true. You can write a layer that will be integrated with the comm port driver which will pass everything on without opening a port. That same layer can make a "fake" comm port made up of only pin 8, which your shutdown device will use.
    Its the same principle on which ComPort Monitors work. I just wish I had all my bookmarks from my old HDD, I had a ton of links on the subject. But if you you'll be fine.
    Oct 2003
    Madrid
    Quote Originally Posted by arkadiyp
    Well, he was only talking about connecting things, not writing 'layers'
    I'd be very interested when you find your bookmarks, in the mean time, I'll google again....
    Mar 2004
    My drive is DEAD, smoke and everything (took PSU and Video Card along with it), from what I remember I found most info on MSDN part of microsoft. Just for the record they are not called layers (at least I don't think so), if I find the info again I'll post it.
    Oct 2003
    Madrid
    And it's probably possible using a Virtual Com Port Splitter such as This, as long as the GPS software ignores pin 8. (and the UPS service ignores the pins that the GPS is using)
    Mar 2004
    And it's probably possible using a Virtual Com Port Splitter such as This as long as the GPS software ignores pin 8.
    That particular one only allows the data line to be monitored by the virtual ports, but the idea is kind of similar.
  1. Replies: 17
    Last Post: 10-03-2004, 04:04 AM
  2. Serial GPS
    By mespork in forum GPS
    Last Post: 05-08-2004, 01:31 AM
  3. Replies: 17
    Last Post: 10-23-2003, 07:51 PM
  4. WTB: Rand McNally GPS Receiver serial version
    By jspeeder9 in forum Classified Archive
    Last Post: 06-21-2003, 11:40 PM
  5. Power Supply for my GPS unit
    By BRINET in forum Power Supplies
    Last Post: 04-19-2002, 09:53 PM
