I had the same mouse, didn't have issues with losing it on hibernate, but my GPS software did.
But all I had to do was restart the GPS part of the software.
Help!
I have a Haicom 203 usb (serial bridge) gps reciever with Infomap Navigator and it works great, until I turn off or hibernate the pc.
When I restart, it boots windows ok and all my other usb devices work fine, remote etc. but my gps doesn't.
The serial bridge is missing from device manager and when I unplug it it makes no remove device noise. The gps reciever has power cos it's flashing.
When I plug it back in it works fine.
In essence it works, but because my pc is in the boot under a false floor it makes unplugging and plugging back in every time i switch the pc on a bit difficult.
Does anybody have any ideas?
It's an Epia M10000 with XP professional.
It's wierd cos the USB bridge vanishes from device manager on both restart and resume from hibernation. I have to unplug it and then plug it back in everytime.
I'm thinking it's something to do with the usb on the motherboard, could be wrong tho.
Mazda 323F
Lilliput 7in
Toshiba Tecra, MapMonkey, DVD, EZ Sync, Roadrunner
Originally Posted by danl
Hi dani,
I hate to say it, you're not the only one with this problem and up to this date there is no fix (but to install xp service pack rc2).
Here is the originalthread
Tell us if you find a solution![]()
Michael
"It does not understand, if it does not ride."
M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
u can download xp Sp2 with any downloader like kazza
or try this page for a download www.kickassamd.com
If it loses connection on start-up then it doesn't sound like the usual hibernate problems that sp2 is supposed to fix. Is it on a hub or an extended cable? Have you tried with only the GPS connected and no other USB devices?
I've tried with just the gps plugged in but it's the same. I also tried devcon.exe to rescan and re-enable the device but that don't work either.
So far only unplugging then plugging back in works.
I'm gonna try something else tho, I'll put a switch in the +5v of the usb cable coming from the gps to the pc and see if cutting the power and then switching it back on does anything. Hopefully it should work like I'm plugging it in again.
Mazda 323F
Lilliput 7in
Good idea! Tell us if it works. I tried devcon yesterday, didn't work for me. I ordered a DB9 serial with ps/2 cable for the gps, unplugging is not an option. I also read that Griffin Powermate has the same prob.Originally Posted by danl
@Laidback, this prob shows also with reboot/start as well as hibernate and not only with usb gps. Another symptom is that USB 2.0 devices get recognized as 1.1 devices.
Michael
Oh ok, I thought it was just a problem with resuming from standby/hibernate.Originally Posted by fly_dutchie
I stand corrected![]()
Sorry for my bad english.
I have the same problem with my gps reciever on Windows 2000 SP4 so Sp4 did not fix the problem.
Does XP SP2 fix it?
It seems lite it's the usb-serial driver wich not working after hibernate/stanby in my case. Maybe you have the same drivers for your devices.
I can use devcon most of the time disable and enable it but sometimes an restart is needed.
