Results 1 to 3 of 3
Thread: slightly disapointed..
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    i installed Routis 2004 on my roomate's laptap. my receiver is the bu-303. this afternoon (around 3) i had clear skies all around. first time testing the program, it got a lock. it maintained like 8/12 satelites. I noticed it was off by about 15-20 feet (i was ahead of where it said i was). thats ok..i can get over that.
    i went back out at 11:30 pm to get some checkers and i could not get a lock for the life of me. the skies seemed to still be pretty clear. i only got 1 lock the whole time and that was for about 5 seconds.
    anyone have any ideas why?
    i read around in some other posts and someone mentioned being stationary until you get a lock. i guess i'll try that tomorrow during my 3 hour drive back to connecticut..and the return trip here in long island. but i really don't know what would make it not work.
    -scott
    rebuilding carpc... kinda..
    Oct 2001
    NYC
    Lot of info on other threads...i'm sure you 'd right?
    receiver more sensitive than deluo?
    Yeah, try staying still and getting the lock before you start moving.
    Where is your reciever mounted? Usually the front dash works best.
    Try holding it on the roof and seeing if it works better and if it does, then you know your glass might have a coating on it.
    Simple things you can try, if anything your reciever might be defective, but try those things first.....
    Nov 2003
    CT
    well, i drove to ct and back...and it worked somewhat flawlessly. theres still the 1 second lag..and sometimes the program would tell me to go back onto the road (even though i WAS on the road)
    i assume the problem i had before with it not working was the combination of the laptop going into standby every 10 seconds when the charger isnt plugged in, and me not stopping until i got a lock. so i bought a 60 watt power inverter..and ended up blowing the fuse after 45 minutes...oh well...i need to find the laptop car adapter.
  1. (slightly) skipping MP3s
    By Nav_Attack in forum General Hardware Discussion
    Last Post: 04-02-2004, 10:50 PM
  2. Replies: 6
    Last Post: 10-26-2003, 12:27 PM
  3. Slightly different LCD ad on ebay
    By pogue1000 in forum LCD/Display
    Last Post: 06-12-2003, 12:53 PM
  4. Slightly different hard drive mounting question
    By Tygur in forum General Hardware Discussion
    Last Post: 05-05-2002, 02:52 PM
