Results 1 to 10 of 17
Thread: routis help
    Sep 2002
    routis help
    does anyone know how to get rid of the "don't use this while driving" nag screen when routis starts up?
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    well...theres no option in the program...which leads me to believe that IF there is a way..it won't be easy
    rebuilding carpc... kinda..
    Constant Bitrate fondoo's Avatar
    Rochester, NY
    i wished i could get rid of it myself.
    rochester ny
    same here, there has to be some way
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    Post
    My friends solution was posted awhile ago on the forums....
    "I use a keyboard macro/hotkey, that does the CTRL+ALT+H for the routis shortcut on the desktop (edit the shortcut settings to accept a hotkey), and then it presses enter after .5 seconds for you.
    I use the speedpad from belkin to do this, but I'm sure there are macro programs you can use for a normal keyboard.
    You can also modify the popup screen to be tiny, and have no text, but I can't figure out a way to automatically return an OK or even bypass that routine completely. It's all in the routis.exe file, so there is no INI file to mess with afaik. I believe it's programmed in Visual C++.
    Interestingly, I can replace all the buttons and some of the menus with colors and shapes of my choice, but I think I like the standard colors even though they look like fisher-price stuff "
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Quote Originally Posted by Squid
    How do you do that? I want to make the Zoom buttons bigger.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Quote Originally Posted by wi77iam
    i'm assuming with resource hacker
    Rochester, NY
    i wish routis would have HOT KEYS that allows you to change the 3D map views on the fly w/o going into display options.
    just started using routis, couple of questions:
    1. is there an onscreen indicator with the bearing of your destination? the only bearing i see is the arrow that indicates north (or toggles to the direction of your travel).
    2. i'm sure the answer is no, but.... i was stuck in traffic on 95 this morning, hopped off the highway and routis kept trying to reroute me back on to the highway. would be great if you could highlight the road in the route list window and right click to say avoid. i don't see any options to avoid roads so i guess the software doesn't do this?
    other than that, no complains so far. im using it with a laptop rather than a touchscreen at the moment, but it looks like it was designed with touchscreens in mind.
    Sep 2002
    i was gonna remove the nag screen with softice but it won't run on my pc. anyone familiar with cracking should be able to do it
  1. Weird Routis Behaviour
    By Wiredwrx in forum GPS
    Last Post: 05-11-2004, 06:44 PM
  2. routis and medicar help plz
    By aznblueeboi in forum MediaCar
    Last Post: 04-24-2004, 09:47 PM
  3. wtb routis 2004
    By awh4992 in forum Classified Archive
    Last Post: 04-20-2004, 01:50 PM
  4. Working out the bigs with MC and Routis
    By shakes in forum MediaCar
    Last Post: 03-26-2004, 01:31 PM
  5. Routis 2004 software
    By greddy0 in forum GPS
    Last Post: 03-02-2004, 06:16 PM
