even worse, I have a Serial Earthmate GPS with a Serial=>USB adapter (laptop doesnt have serial) and havnt been able to get it to work with Routis either.
Is there any way you can get Routis 04 to work with Delorme Earthmate USB?
I would like to use Routis instead of Street Atlas, but Deluo stated that the software doesn't work with Earthmate USB receiver. Is there a way around?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
2000 Jeep Cherokee
-CarPC: [»»»»»_____]50% complete
-planning done, still need a few parts
-In-dash motorized VGA is finally out, need $$$
-Need to replace factory HU
I haven't been able to get my usb Earthmate to work with Routis yet, using the latest usb-serial drivers from DeLorme. As soon as I select the comm port in Routis, I get the BSOD. Routis says it's the drivers that are at fault, but it is odd that I can run the Earthmate with the usb-serial driver on Mappoint and every other GPS program just fine.
I would keep trying to get this to work, but when I use Routis with my Magellan hand-held, I'm coming to the conclusion that Routis is just not worth it. Sure the 3D maps are nice, but the small fonts and small zoom buttons make me want to go back to my Street Atlas with its large fonts and voice command.
I like SA but the routing is $uck. If I intended to take a wrong route, it doesn't recalculate (I did enable the option) new route. Voice command after an intended "wrong way" is out of sync and useless.
I want to see other options
Woohoo. Finally got it to work. Thanks to Mr. Curiosity and his xport comm port splitter.
You set up your Earthmate to use the usb-serial driver and assign it a comm port. Then you run xport and select the Earthmate port as the hardware port and select a virtual port. Then you need to run any program that will "drive" the Earthmate, like another gps program or even just hyper-terminal. Then start Routis and select the virtual port.
Viola!! Routis is now running with Earthmate.
Curiosity, you da man.
That is freaking good.
The process is kinda cumbersome, but much better than not working at all.
wi77iam is it a one time deal or everytime you want to use routis with earthmate?
very nice find, thanks for the info
I'm guessing its everytime you want to use Routis w/ Earthmate...
how would you use a hyperterminal to drive the gps? that seems like the ideal solution, cause SA takes forever to load, and takes up system resources
2000 Jeep Cherokee
You can set up the Earthmate to always use the usb-serial driver. Then you just have to start the xport program, start the gps driver program, then start Routis. Could all be done with a batch file on startup.
nice nice, thanks for the info wi77iam.Originally Posted by wi77iam
if you save the connection info, then set it to start automatically with windows.... perfect.... now all thats left to do is figure out a way to have it automatically run hidden in the background.... anyone have any simple utilities up their sleeve to do that? :d
2000 Jeep Cherokee
