Update rate has a range of 1-255 seconds, this is evident in the datasheets covering NMEA, SiRF, and possibly Rockwell. I'm sure there are other protocols, but it seems the lowest update rate is 1 second. It is not so much the update rate as it is the accuracy of the gps device that matters. I would recommend something WAAS enabled. 1 second is perfectly fine for civillian gps usage anyway as it is perfect for speed calculations, etc.
LinkBack URL
About LinkBacks
