Results 1 to 4 of 4
Thread: Deluo GPS and Navigon incompatibility?
    jhu
    jhu is offline
    May 2004
    I just hooked my Deluo USB GPS on my laptop to use it with Navigon MobileNavigator for the first time and a very strange thing is happening.
    Netstumbler and Alturiion GPS both "see" the GPS signal, but the Navigon says there is no signal attached. I've switched Com ports, but the problem remains.
    Is there a possible problem between the Deluo GPS and the software?
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    make sure all the settings are correct. the deluo unit is an NMEA reciever, so any program that uses NMEA will work.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Low Bitrate BeamRider's Avatar
    Genova, I
    It's Navigon default configuration....you've to change the SPGPS.ini
    If you still need help on it leave me a PM .
    Installation: 90% complete - fiberglassing
    EPIA M10000 - 512Mb - 20GB
    Lilliput 7" TS - Opus 150W PCB - DLink USB Radio - slim CD-ROM - SoundBlaster MP3+ - not so crappy 40x4 Amp - BU303 GPS (waiting for) - BT support
    May 2004
    Mobile navigator only needs the NMEA GGA and VTG output sentences.
    Program your gps device to send only those 2 sentences, and it should work.
    I used u-center to set it up, but you can also use sirfdemo.
  1. GPS Software for X86 PC and 7" Touchscreen
    By segerdahl in forum GPS
    Last Post: 09-05-2005, 12:50 PM
