Results 11 to 20 of 21
Thread: Copilot Live Laptop 7 hacks
  1. #11
    Variable Bitrate wkolodny's Avatar
    DC
    Quote Originally Posted by antimatter
    How are you guys doing this.
    Do you think it would be possible to get this thing to display correctly in say mediacar.
    Copilot 7 takes up the whole screen so you cant switch back and forth between mediacar and copilot.
    I guess if we could atleast size the window it would work or atleast make it so copilot is running within a window instead of full screen
    There is an option under copilot 7 to always show the task bar. Makes switching between apps easier.
    Don't Fear The Gurkey
    Click here to check out My Setup
  2. #12
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I tried that but it didn;t seem to do anything. I will try that option again and see what happened. Though it isn't the slickest soulution i think it will have to do for now.
  3. #13
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I believe it would be possible to display just the map...if you had a way to interpret the calls required...
    It seems the guidance page is an xml (or) VB type overlay. It uses the bitmaps in the bitmap folder for SOME of the icons etc.
    However it also uses some imbedded bitmaps within that same section of code previously mentioned.
    So right now I am trying to figure out how to view those bitmaps, then edit them. If I can view them (assemble/disassemble) then I can change them.
    Basically half the backgrounds are bitmaps, and the other half are encoded...almost looks sloppy, but I am sure there is a reason.
    Can anybody out there direct me to a program that will reassemble bitmaps from the code? (hex)?
  4. #14
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    antimatter,
    Have my Mediacar screens designed at 800x570. That leaves my task bar showing and I can keep mediacar running while I use the system for other things.
    Batman
  5. #15
    Jan 2004
    California
    That will definatly work but i am trying to stwy away from having to do that.
  6. #16
    Jun 2004
    Switzerland
    Resource Tuner
  7. #17
    Jan 2002
    St. Michael, Minnesota
    Any Updates on this?
    Are there any updates on this? I would love to be able to try out LIVE on my 10.4" (640x480) Pretty much worthless out of the box.
    Nathan
  8. #18
    Jun 2004
    What about an auto-hide taskbar. That way you have the benefit of the taskbar when you need it but you don't have to have it ruining the looks of MediaCar
  9. #19
    Oct 2000
    DFW area
    Oops, sorry, I got slowed down by the graphics. I can't find an easy...or any way for that matter...way to edit the internal graphics down to size. I can edit everything else, but it gets lost while trying to remap the buttons around the display. You can get a real nice pic with 800x600, but 640x480 is really being difficult.
    Still working on it.
  10. #20
    Oct 2000
    DFW area
    Hey that resource tuner program is fantastic...much better than the two others I tried. I may be closer to finishing than I thought.
  1. CoPilot Live 7 - Special price
    By Zip-Lock in forum GPS
    Last Post: 05-26-2004, 09:38 PM
  2. WTB: Copilot Live 7 (for laptop)
    By Ninety8NeonACR in forum Classified Archive
    Last Post: 05-02-2004, 11:21 AM
  3. ME 2.1.4 and CoPilot Live 7
    By Izik in forum Media Engine
    Last Post: 03-14-2004, 11:32 AM
  4. UK Copilot Live 7 ?
    By CdRsKuLL in forum GPS
    Last Post: 02-23-2004, 02:32 PM
  5. CoPilot 2003 vs. CoPilot Live
    By XxAndyxX in forum GPS
    Last Post: 02-11-2004, 11:50 PM
