Thanks, I think I know what that is, corrected in next version.Originally Posted by pottillo
Program give me run time error 13 whaen i hit start after loaded database and connected gps.
Speed camera detector for Windows, can work alongside any other GPS application(s);
EvetS page
What I really like about the snooper are the voice alerts telling you the speed limit / distance etc... Perhaps you could use the MS text-to-speech engine to incorporate this?
or even better - have the the option for the app to constantly output all the details to a file so we can write our own apps to deal with it (For example I'd want to have it mute winamp while it was talking)
It'd be great if I could replace all the functions of my snooper completely :-)
Done this a while ago using HTTPLook and spent a few hours sitting down doing radian/decimal calculators on the data converted from hex to no avail - feel free to give it ago.Originally Posted by g_attrill
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
Yeah, could hook up TTS easily for real time speech.Originally Posted by Ninja Monkey
Writing to a file and another app reading said file, both in 'realtime' would be very messy - I could offer an IP connection? eg 'host' it on a localhost port(127.0.0.1:9999) and output keywords - that would be a much neater way of making it work with your apps (your app would simply connect via a winsock control and listen for events)
EvetS page
Ok - the 2nd revision is ready for download (0.95) - now includes various options (minimise to tray, start on load, port config save etc) a much improved calculation routine (less CPU load and faster running) and the ability to connect to it with your own application. (VB or otherwise, uses IP so is fairly universal)
VB demo code for how to connect to the application is at the bottom of the page.
Haven't tested it fully 'on the road' yet so there are bound to be a few bugs!
Next revision will include any bug fixes found here - speed display along with estimated time to camera (including time alerts, so can set it to trigger voice when 10 seconds away, rather than just distance option)
EvetS page
tested version 0,95. Same run time error n. 13 when i hit start button. If the db is loaded or not or the gps is connected or not, still same error 13. Can this be related to the use of a non english verion of WinXP?
Hmmm interesting, any other information with the runtime error?
Could you download this one for me and put it in the same folder as the main files you already have - then run debug.exe amd hit 'start' again, and tell me what messages it flags before crashing, will help me pinpoint where it's going wrong.
debug
EvetS page
Wow!
Excellent app, just what I've been waiting for. Cant wait to test it tonight. This will be so cool when driving with friends.
No messages... when i connect gps it correctly receives gps string, i load db with no errors but when i hit start i receive error 13 and no other message. The onlyu infos i can send are those of ms win error windows (i don't know if it is useful or not):
AppName: debug.exe AppVer: 1.0.0.0 ModName: debug.exe
ModVer: 1.0.0.0 Offset: 00013694
