Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 82
Thread: UK Speed camera detector, for any PC with GPS
  1. #41
    Newbie Goto10's Avatar
    Jun 2004
    Essex, UK.
    I noticed this earlier as it happens - must be the 'improved' routines I did !
    I'll get my thinking cap on and work a way around the fluctuations.
    The announcements not sounding is quite odd, again I'll run through it with a fine toothed comb...
    Quote Originally Posted by Jamez_Warner
    very nice but your code is flawed somewhere, say im 250 away from a camera it won't always beep ( the software shows it should ) and sometimes doesn't tell me about the speed camera untill i've passed it ( again i've set it to give me the final warning 200 meters away - software can be saying 50m away and it doesn't say anything... )
    also i'f im still and the gps is stable ( no change on map in gps nav) your app flucates nearest cam just wanders about between 50m and 400m
    anyone else seeing this?
    James
    Speed camera detector for Windows, can work alongside any other GPS application(s);
    EvetS page
  2. #42
    May 2003
    UK
    thanks goto - apart from that very nice, the faint beeps are ideal just to alert you somethings near without being annoying - what would be cool is an option to make the "warning speed camera" only sound once per camera otherwise i usually get warned over 5 times coming up to a camera at 30
    James
    www.digital-car.co.uk - The UK CarPC Forum
  3. #43
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    very nice goto, works well, the beep gave me a shock at first tho
    Just 1 thing, since running this will XPort my carpc takes a lot lot longer to shutdown, it isnt shutting down b4 my ITPS cuts power. When ic lose them both manually and then shutdown its fine. Any ideas on hwo to fix it?
    Cheers
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
  4. #44
    Newbie niwa's Avatar
    Jun 2004
    Reading, Berkshire
    Still love this application, its cool. An earlier comment said that the database was out of date, and yes its quite old. Is there any new "Road Angel" type updated database coming out soon. Keep up the good work!!
  5. #45
    May 2003
    UK
    any luck on the bug goto?
  6. #46
    Jun 2004
    Essex, UK.
    Yes, almost there, luckily I've been out and about recently so I've had a chance to test it properly! Options to limit number of beeps etc are now in place, just sorting out the 'jumping' at the moment - mainly just a smoothing algorithm to try and iron out silly GPS inputs - much like the map software does I'd imagine... Hopefully have something ready for next week.
    Regarding getting the data from a B2 unit or similar - I've worked out most of what the data means now so might start hosting 'current' data on my webspace for download, includes speed limits, direction of camera etc - that'll be another release away yet though!
    EvetS page
  7. #47
    Feb 2004
    good stuff goto, any idea on the shutdown problem?
  8. #48
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    Hi, just had chance to test this software - great work!
    Just an idea. Sorry if this has been suggested elsewhere but I've very little time to post/read recently: -
    Would be great with a big button that you could press when passing a speed camera it doesn't know about. It adds the camera to the "current" database, and also into a separate file that can be sent to mobilegpswhojermacallits to update their central database. There's about 20 new cameras round me I could add for a start
    Also had a problem in that it wouldn't let me hibernate when it was running. Not sure if this was your software or that xport thing will investigate more if I get a chance, but it's imperative that I can hibernate.
    Great work tho, keep it up!
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
  9. #49
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    xport doesn't hibernate yet..
  10. #50
    May 2003
    UK
    nor standby
  1. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  2. Rand McNally GPS drives my PC WILD...
    By SuperMatty in forum General Hardware Discussion
    Last Post: 03-27-2003, 01:01 AM
  3. Replies: 5
    Last Post: 10-24-2002, 12:00 PM
  4. max cpu speed in a book pc model #bki810
    By Ces///M3 in forum General Hardware Discussion
    Last Post: 01-27-2002, 03:41 AM
  5. gps for a in-car pc?
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 01-20-2000, 09:34 PM
