found this:
Routis Mouse Problem....
I did the manual registry edit, just like it says, instead of the patch by routis, haven't had anymore problems.
BTW Logitech did make some serial mice. We have a couple around the office.
Sometimes if I reboot, my mouse cursor goes NUTS. If I unplug my GPS, it stops. Some say its the mouse being detected wrong, but its not. Its listed as the Logitech mouse, not a serial mouse.
Any suggestions?
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
found this:
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
This is an oldie problem. Goto your controls, mouse and disable the "mouse"
Then the gps will work only as a gps receiver
Mine needs to be updated.
Doh!, I must have missed that in my search. Thanks! we'll see if this helps.
Thanks again.
I dont wanna disable the mouse, Im using it in my home until I have th PC setup how I want it.
