Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: Earthmate not weatherproof need help
  1. #11
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by veetid
    Well... I dipped my last night.. Letting it dry today... I will then test it out and post a picture... Looks pretty awesome.. and there is no way water will ever get in this thing.... I also dipped down the usb cable all the way into the car, so everything outside is covered with rubber....
    If the rubber material is that good, I guess you could remove the plastic housing before you dip. That should reduce signal degradation a little.
  2. #12
    VENDOR - Centrafuse veetid's Avatar
    worked great... I hooked it up today and received 10 sats... It looks like the extra plastic didn't hurt my signal.. I will post a picture after work...
  3. #13
    Here is a pic... Works great....
  4. #14
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    wow..that looks good. so much better than the original yellow.
    thanks for posting a picture
    EDIT: can you post a picture of how it looks mounted on your car? or maybe give some details on how you mounted it
  5. #15
    Maximum Bitrate mobileh1's Avatar
    San Francisco
    The TripNav is waterproof and works great. They are so inexpensive, you can throw it away and get another one if it dies on you.
    Bottom line on interior mounted GPS units... poor reception. They work sometimes, but under anything other than ideal circumstances they perform poorly.
    Remember the antenna needs a groundplane, so mount the thing on the biggest hunk of steel you car has that faces skyward.
    The US DOT mandates that car roofs are steel. Personally I think this was to ensure that everyone has a good groundplane, but there are other theories...
    If you want it to blend in and look pretty paint it to match. If you have a roof rack then you can mount it discretely without much problem...
    Goodluck, hope it works out well... The rubberizing looks awsome! I want to rubberize my whole car!
    .//Daren
    (Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
    MediaCar/CoPilot7/Routis
  6. #16
    Mar 2004
    Plasti-Dip
    Quote Originally Posted by jdaniels
    I weatherproofed mine by buying some "Plasti-Dip" from Lowes, it's for dipping tool handles in and it makes a permanent coating (or pretty damned close) over anything...
    Where in Lowes is it located? I searched my local lowes, but couldn't find it anywhere, and the employees were NO help.
  7. #17
    Constant Bitrate TaylorMade's Avatar
    Nov 2003
    Tampa, FL
    NOOOOO doubt. I swear I honestly don't know how Lowe's stays in business around here. Their employees (in my two local area stores) generally don't care a bit about you. I actually had a guy once tell me he was coming right back to help me and walk down the aisle, take his apron off and walk right out to the parking lot, get in his car, and leave. Sickens me.
    Anyway, this was just a reason to bump this thread, and get my Lowe's hatin' in at the same time. Are there any updates to this? Still working? Any pics or ideas on how to mount them once they're dipped?
    2008 Ford Expedition EL Ltd
    Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
  8. #18
    May 2004
    TX
    Quote Originally Posted by Bama5150
    If I'm not mistaken..it should be located in the paint aisle.
    I just bought it a couple days ago at the local Lowes here in TX and it was with the paint cans.
  9. #19
    Constant Bitrate ccblanket's Avatar
    Sep 2003
    SF Bay Area
    I bought the plasti-dip thing the other day. It's $6.9x and is amazing. I did 4 coats on my earthmate w/out the (yellow+black) plastic housing. It is in the paint aisle, sitting next to spray paints behind the bars/grills (they are locked).
  10. #20
    May 2004
    TX
    Quote Originally Posted by ccblanket
    Could you give a little more detail. What is under the plastic housing? Is it just the circuit board underneath.
    Can you please post a picture?
  1. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  2. Replies: 21
    Last Post: 06-30-2004, 01:17 AM
  3. Threw out my DeLorme Earthmate
    By drmaximus in forum GPS
    Last Post: 04-27-2004, 08:18 AM
  4. FS: Earthmate GPS and Street Atlas 2003
    By bridqer in forum Classified Archive
    Last Post: 02-15-2004, 02:14 PM
  5. Replies: 5
    Last Post: 01-04-2004, 09:43 PM
