Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: Earthmate not weatherproof need help
  1. #31
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    bump
  2. #32
    Low Bitrate fishy's Avatar
    sydney
    bu-303
    i dont have an earthmate, BUT i do have a BU-303 that i was going to open up to "CONFORMAL COAT".
    Ya'll prolly know what this is, but for those that dont, it is a spray on substance designed specifically to water proof PCB's. I was going to open up the BU-303, conformal coat the internals, let it dry, put it back together, then run some D-MASTIC (or N-MASTIC) by shellys around the outside and seams, this way, i can open it again if i want to, without having to peel all that rubber off, and its water proof (mastic is used to hold the windshield of your car in, and weather proof it) one of the mastic range stays tacky, the other drys with a skin, i just cant remember which is which right now.
    thats my thoughts....
  3. #33
    sydney
    success
    well, i thought i'd post an update - conformal coating the internals works just fine (as this is what conformal coating is designed for) it keeps moisture/condensation from forming on the internals also.
    My BU303 has survived sydneys crazy rain storms, so im pleased, and it all looks nice n factory from the outside, the magnet is still as effective, and it wont matter if i forget too remove it after a journey and it rains.
  4. #34
    Constant Bitrate TaylorMade's Avatar
    Nov 2003
    Tampa, FL
    I can add, as an update, that I did, in fact, drill a hole through the roof (gut check) and then sealed it... it took the South Florida heat and rain just fine for approximately 4 months. Just sold the Jeep, so dunno how long it would have lasted.
    2008 Ford Expedition EL Ltd
    Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
  5. #35
    Feb 2005
    New Orleans, LA
    anyone dip the earthmate without the plastic cover...seems like it would be a bad idea, but it would cut down on the size a bit.
  6. #36
    Constant Bitrate ccblanket's Avatar
    Sep 2003
    SF Bay Area
    I did, and it worked real well.
  7. #37
    Feb 2005
    New Orleans, LA
    cool thanks, how did you get it to stick to the outside of your car...I'm thinking magnent, but it is hard to find one that small that is strong enough...my speakers are afraid of me right now.
  8. #38
    Feb 2005
    New Orleans, LA
    FYI- this stuff eats electrical tape also. Found this out the hard way.
  9. #39
    Nov 2003
    Tampa, FL
    I used clear sealant (read: caulk) and it stuck till the end.
  10. #40
    Feb 2005
    New Orleans, LA
    I ended up dipping the magnet and the GPS separatly, then sticking them together after about 4 hours of drying when it is still a bit tacky...don't think they will ever come apart, the dip is really sticky stuff. Cant wait to stick it to my car and see what kind of reception it gets
  1. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  2. Replies: 21
    Last Post: 06-30-2004, 01:17 AM
  3. Threw out my DeLorme Earthmate
    By drmaximus in forum GPS
    Last Post: 04-27-2004, 08:18 AM
  4. FS: Earthmate GPS and Street Atlas 2003
    By bridqer in forum Classified Archive
    Last Post: 02-15-2004, 02:14 PM
  5. Replies: 5
    Last Post: 01-04-2004, 09:43 PM
