Results 1 to 10 of 14
Thread: Dual GPS Rcvr's. Unusual thought...
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Just been doing a bit of thinking (hate when that happens).
    Logically, the best spot for a GPS receiver would be right in the center of the roof. Now that's not gonna happen. That'll be ugly and require a hold to be drilled in the roof. Naah, I think I'll pass on that.
    Picking either the rear deck or on the front dash limits the receiver's view of the sky. Also, depending on direct of travel along with any obstructions.
    Do you guys think it's possible to get two receiver's and hardwire them together onto a single USB cable placing one receiver in the front and one in the back. In theory, the software should only see one device but get the information from both perhaps also increasing accuracy because it will be able to "see" more satellites.
    What do you guys think...
    EDIT: A couple of good points have been brought up in this thread.
    1. The software may not like getting multiple data streams.
    2. It may be possible to use multiple antennas instead.
    3. The GPS won't use all the sats. at once (only 3 are needed for position, 4th for elevation).
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Maximum Bitrate dodgetimes2's Avatar
    MI
    I was pondering this as well, but it might also "confuse" the software when it's constantly getting 2 sets of different data strings. The 2 sets of data strings will always differ by X amount of feet (X=feet between receiver 1 and 2). Would like to see someone test it though.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Oct 2003
    Toronto, Canada
    Chances are your gps reciever wont even get anything at the back window, as many have people found out the hard way...
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Mar 2002
    Austin, Texas
    Quote Originally Posted by [iG]
    It probably depends on the angle of your back window and the GPS placement. I've got mine in the front window in the top corner. Works pretty good the majority of the time (when testing with laptop).
    Derek
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    IMO, Zero chance with USB and possible with Serial but how do you control when each can send a string? If they both send together you'll end up with garbage.
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Why have two GPS receivers when you can just have two external antennas connected to one receiver?
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    IMO, I think one GPS antenna on either the deck lid or the front windshield will have enough of a view at all times to get a good signal. I don't think you'll see too many more sats with one verse the other. Furthermore, from my limited knowledge of GPS (I could be wrong), just because you have 10 sats doesn't mean it's using them all. Just the best ones to locate you.
    Furthermore, I could just imagine that feeding the software two strings from two diff receivers in two different places will simply serve to upset the software and not perform its task.
    Sorry.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I doubt there would be any benefit to using multip GPS receivers. The typical positional error easily covers the length of most cars/trucks.
    Regradless, if you plan to combine the two output streams, you're going to need some form of flow control. Otherewise the receiving software will not see a valid data stream at all. It might make more sense to hook the two receivers up to their own ports and then use a software layer to combine them to a virutal port. This would be quite easy to implement.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I agree that if you have your reciever in the front window, you should be able to get a decent signal. All you need is 4 satellites to get a 3-D fix. And depending on the software package you are using, you may only need 3. As for combining the signals, you WILL have to have flow control, unless you have 2 serial ports. Once you have the signals in the computer, you could always have a very simple program scanning the incoming data for the $GPRMC strings and combine them and then output them to a virtual port that the GPS program is looking at. As for the other strings, you could just let them pass directly through, maybe with a little editing.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Raw Wave
    Jun 2003
    If you plan to use 2 GPS one placed at the front and one placed at the back of the car. As been said each one need to be connected to a serial port.
    A software need to sample both the $GPRMC sentence coming from the GPSs. Other relevant sentences can also be processed. The position is then averaged out, the new NMEA sentence together with a new checksum is then outputed to a virtual port. You cant just mix them, its pointless otherwise. The software doesnt like to be bombarded with the same sentences too often either...I have tried it before. It must follow the NMEA sentences being fed into the software once every seconds.
    All this in theory will give the position of the centre of the car...giving a more accurate position. The software should also know if one of the GPS output is not valid for navigation and therefore switch over to the good GPS...just incase one of the GPS lost the lock.
    Can be a little bit tricky but I think it is possible. A PIC MCU should be enough to even do this if a standalone unit is the goal.
    You wont be able to pick up more satellite this way, but for accuracy it should work.
    Not sure what exactly can be gained as I dont think its economical but I would love to see it working though.
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  2. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  3. Replies: 1
    Last Post: 06-11-2004, 03:10 PM
  4. Replies: 4
    Last Post: 09-04-2003, 10:20 AM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 03:26 AM
