Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Is the Delorme Earthmate better than the Ebay "GPS mouse"?
    Jun 2000
    NYC
    From experience, do u think it's worth it paying more.
    Reliability?
    Locking with sattelites?
    Anything else?
    I have some gift certificates to Staples so I was thinking on using them for the Delorme.
    Thanks for your input.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    i can lock on to satelites in around 25 seconds with the earthmate.. i would recommend it to anyone.. at least the USB version
    '98 Explorer Sport
    80% done
    Constant Bitrate jpelzer's Avatar
    May 2004
    NYC
    And I've had good luck the the eBay mouse... BUT... It takes freakin' forever for the eBay mouse to arrive... I waited almost 3 weeks. So the Earthmate has the fact that you can pick it up on a store shelf going for it.
    GPS technology is not complicated... At this point the market has settled down, you're not going to find much differenced in these low-end receivers. You'll be happy with either one.
    Cheers!
    Apr 2003
    I hated the Delorme Earthmate. Under my steep Dodge Intrepid's windshield, I'd often lose signal while driving, and it wouldn't have enough time to lock even at traffic signals. My spite for the item was only increased when I found that it wouldn't work on a Wake-from-Standby unless I disconnected and reconnected it, so I had to have my computer shutdown completely while I had it. Therefore, when I started my car I had to wait a minute-or-two for it to boot up, then I had to wait a minute-or-two to get a signal lock, and if I left my driveway before that it'd often not lock on my entire 30-minute commute to work.
    Admittedly, using Delorme's specific GPS drivers and Street Atlas 2003 would work after coming from Standby, but Street Atlas 2003 may be the only thing I hate more than that stupid yellow Delorme. Without street-road locking, I was always 10 feet off the road (which I didn't know was a problem with the maps or with the GPS), which made all the directions it may have given me incorrect, and just didn't seem friendly with a Xenarc touchscreen.
    Admittedly, I've read of others who have modified the Delorme to take power from another source to alleviate certain problems, but why should it be my job to make their product work? The only thing good about the Delorme was that the multi-colored LED on it let me know just how badly it was receiving satellite signals (Green, Yellow, Red).
    Since then I've switched to Deluo's GPS mouse, powered from the PS2 keyboard and sending data through the COM port, and I highly recommend it. Satellite signal locks come faster, are lost less often, and it doesn't require special drivers to work (with the COM port, I haven't used the USB portion, though I'd assume the same wake-from-standby problems exist on Deluo's USB). Furthermore, it's weather-resistant nature lends itself to an external mounting, if I someday find a nice way to put it on my roof (by the way, does anyone know a nice way to externally mount these? Like the plastic cover that I see on my friend's Honda Accord?).
    Given the similar price points (Actually, I believe Deluo's is cheaper than Delorme's), I'd recommend Deluo's GPS to anyone who asked. Sorry I don't have more advice regarding the generic black eBay ones that are available.
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I've got an Earthmate and it works great, but I had the same experience that Sensor had with hibernate not working. I modified a USB cable to provide constant power to the Earthmate, but it still wouldn't come back from hibernate some times. Eventually I solved my problems by purchasing a serial cable from Delorme and not using USB with the Earthmate. I have absolutely no problems now running via the serial port. I think the cable was an extra $30 dollars from Delorme, but you can also hack up the USB cable to make your own. I think the Delou mouse is cheaper and I've read elsewhere that they are running a sale right now. I just checked their site and they've got a great deal right now on the serial mouse bundle with Routis for $139 plus shipping (USB cable is $10 more).
    http://www.deluoelectronics.com/cust...&cat=17&page=1
    The site shows $149, but when you add it to the cart it comes up as $139. A great bonus is that you'll get a free upgrade to the new version of Routis which is coming out any day. Hope this helps!
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    I have the earthemate and hate it - does not work properly with Streets and Trips (though that is not what I will be using it with). I also have the wake up problems that everybody esle has noted - IMHO it is a pain to use and I would never wire it into a carputer since it is so flakey. There is just something wrong with a USB GPS that needs a USB to serial driver to work (at least with Streets and Trips)- might as well use a serial GPS which seems to be what Sensor found the least troublesome. I think that I will get the Deluo's GPS mouse like Sensor has since he seems happy with it.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Just one word - WAAS (is that a word?) Earthmate has it, DeLuo doesn't (at least they don't list it in their specs, which means they probably don't have it).
    With the newest drivers, the Earthmate works with every program that I've tried - SA, Routis, Mappoint, etc.
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    The Earthmate has been working pretty good for me. If i let it lock before I start moving I have no problem. Even if its after hibernation. I usually initialize it with hyperterminal on start up also. Then I use it with Routis 2004 (thanks to Curiosity's Xport software).
    Every once in a while it will lose lock for a moment. I have it sitting on the rear deck towards the corner. Theres another guy that is covering his with plasti dip to make it weather proof. I'm waiting for him to give more info on how its working out and then I may do it to mine. I'm pretty sure that if mounted outside the car, the Earthmate would work flawlessly.
    May 2004
    AZ
    Wi77iam, thanks, I am planning on using Routis if it gets embedded in Frodo or MediaCar, will hang onto the Earthmate till then and give it a 2nd chance
    My experiences with it to this point however are still frustrating.
    VENDOR - Centrafuse veetid's Avatar
    I love my Earthmate... I purchased the serial cable from delorme and now its a standard NMEA serial devices... No drivers to install and it works with all GPS software and standby, hibernate.. I also used some "Plasti-Dip" and dipped my Earthmate and covered it with black plastic.... This made it 100% waterproof and also not yellow... Now that it is waterproof I put it on the top of my car and usually get 10 sats and lock on in seconds...
  1. Replies: 39
    Last Post: 09-16-2004, 11:12 PM
  2. Threw out my DeLorme Earthmate
    By drmaximus in forum GPS
    Last Post: 04-27-2004, 09:18 AM
  3. Replies: 12
    Last Post: 11-05-2003, 01:06 PM
  4. Replies: 17
    Last Post: 09-10-2003, 05:01 PM
  5. FS: Delorme Earthmate USB + Two 802.11b NICs
    By Kessler in forum Classified Archive
    Last Post: 08-14-2003, 12:47 AM
