Results 1 to 5 of 5
Thread: GPS Worked great - now doesn't.
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    So, I drove for 2 weeks across the country through all types of heat and rain with the GPS Mouse (ebay unit) running out the window and stuck onto my roof. It's been hot, it's been wet (waterproof unit) and it's been great .. until 2 days ago.
    The unit will get a signal from satellites (I use Routis and it shows the 'degree' of lock it has -- i don't know how tobetter describe this), but it doesn't lock on any. I see that Routis is recieving information from the GPS unit (the long/lat fly by), but I never get 'green'... THEN!! every once in a while, 3 or 4 satellites will lock on, but have slow refresh rates.
    I get the same results when I use the GPS software that came with the unit. Any ideas?
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
    Jan 2004
    Sweden
    I had the same problems with mine.
    I got mine on the inside of my car.
    Is it a BU303? I don't know what I did, but I just changed USB-port and since that it has worked perfect for me.
    Nov 2002
    New Jersey
    Yes, it's the BU303 -- I'll try a different USB-port... maybe it's a driver problem or something. Thanks for the reply....
    Quote Originally Posted by storm
    -Brad
    83 mp320i
    99 mp323i
    _________
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by captain_jim1
    I took my BU-303 through a car wash and it stopped working completely - for 24 hours! I thought it was broken (it had no light on at all, let alone blinking).
    Think it's safe to say the BU-303 isn't water proof, maybe splash/rain proof to a certain degree. After that day, I haven't kept it on the roof since
    Good way to check it's working to some degree is to use Hyperterm to connect to it it (at 4800 / 9600 baud) and see if you see the familar $GPRMC etc lines, if the lat/lon are 0000.00000 or similar the chip is working but can't get a lock.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Try sealing it with a small bead of silcone sealant round the casing seam, cable outlet, and the LED hole... That should water proof it nicely!
    HTH
    John
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  2. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  3. Great European GPS software 4 touchscreen
    By schakenda in forum GPS
    Last Post: 02-24-2004, 04:46 AM
  4. Cant get good GPS signal in car.
    By Ricky327 in forum GPS
    Last Post: 01-29-2004, 10:28 PM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 03:26 AM
