Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: No Lock, WHY!?!?
  1. #21
    Constant Bitrate nibix's Avatar
    May 2004
    It's an SUV
    2004 Freelander HSE | Lilliput 7" VGA Touchscreen| Via M10000 | 256 MB | 120 GB | DVD player | TN-200 | Opus 150watt |Windows XP Pro | Media Car | Routis & Destinator
  2. #22
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    weather proof it with Plasti-Dip and mount it outside the vehicle.
    I plan on doing that this week. Veetid did it not to long ago in another thread
  3. #23
    Maximum Bitrate mobileh1's Avatar
    San Francisco
    This cannot be stressed enough, the band that GPS operate on is very sensitive, you need to have a ground plane and have clear unobstructed view of the sky. This means mounting the antenna outside the vehicle, on steel.
    The heated windshield in my vehicle completely obliterates any GPS signal, also the trouble with windshield mounting is that you only have a limited view of the sky. Im lucky, my hood/bonnet is fiberglass, so I have mine mounted on the battery cage (steel) which protects it from the elements and allows great lock.
    .//Daren
    (Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
    MediaCar/CoPilot7/Routis
  4. #24
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    I have the same kind of heated windscreen which also blocks GPS coz of it's metal coating.
    When I had the GPS on the roof 6-10 sats. When I mounted it on the left side of the dashboard 2-3 sats. When I mounted on the right side 6-10!!
    Weird !!!
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  5. #25
    San Francisco
    Not wierd, the wires in the windshield act like a polarizer, so just like the sunglasses, the attenuation varies with the angle presented to the sky.
    .//Daren
    Quote Originally Posted by stevieg
    Weird !!!
    .//Daren
  6. #26
    May 2004
    TX
    ground pane, eh? i didnt know that but it makes a lot of sense.
  7. #27
    Raw Wave
    Jun 2003
    Ideally yes but not necessarily true...
    It worked well for many poeple without having to install it outside the car. It just all depend what sort of material is in front of the GPS receiver.
    Isnt the heater wires too wide apart for the signal to be affected?
  8. #28
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by Ricky327
    Mine in the front are not more than 1/2 cm apart and def. affect the signal.
    Lots of GPS devices are made to sit inside the car - For example the new generation of speed camera detectors which use GPS to find the location.
  9. #29
    Oct 2003
    Smile Magnetic?
    Quote Originally Posted by nibix
    It's an SUV
    Isn't the thing magnetic? You can stick it to the upper part of the hood at the top of the window.
    Mine was magnetic; I can even stick it where the passenger door window meets the metal frame (inside of course).
  1. Receiver won't lock!!
    By Bobby Digital in forum GPS
    Last Post: 05-09-2004, 07:59 PM
  2. gps takes forever to lock!
    By aznblueeboi in forum GPS
    Last Post: 04-22-2004, 11:52 PM
  3. Replies: 11
    Last Post: 01-31-2004, 07:57 PM
  4. earthmate wont lock onto satellite
    By aoLhaTer in forum GPS
    Last Post: 06-12-2003, 10:58 AM
  5. Replies: 4
    Last Post: 05-26-2003, 01:19 PM
