When you hibernate you kill power to the GPS receiver... There is no way for it to keep its sat lock with no power... The unit itself is what actually locks onto the sats.. However in the amount of time it takes to come out of hibernation, your earthmate should have enough time to re-lock the sats (usually takes mine about 30 seconds to lock)... I use to have the same problem you are having with my earthmate... It was the USB/serial drivers that was causing it for me... You need to use the serial cable for your Earthmate... You can either purchase one from Delorme or make one yourself...
LinkBack URL
About LinkBacks
