Results 1 to 4 of 4
Thread: garmin mapsource vs road star usb mouse
    Newbie kistian's Avatar
    Jun 2004
    Gerona [SPAIN]
    Exclamation garmin mapsource vs road star usb mouse
    I have the mapsource and a usb mouse from road star (model RN-202)
    the mapsource can't find the reciver via usb or virtual serial port
    there is somebody with similar problem or anser?
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    Do you have the reciever set to the same protocol that mapsource uses? Or have mapsource set to use the protocol that the reciever uses? Thats what I had to do to set my garmin unit up, may be the same for your usb mouse, or it could be that the USB mouse doesn't work with mapsource.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Jul 2004
    I have a Garmin GPS V and use mapsource that came with it. My mapsource software is locked to the GPS V serial number. Garmin required me to register the serial number of the GPS unit, then they sent me a key to unlock the software which will only work with the correct serial number of the GPS unit. I believe Mapsource uses the "GARMIN" communications format.
    Jun 2004
    Gerona [SPAIN]
    how I know what protocol use my reciver?
    I have use it only with the driver, transform it in a virtual serial port (com3) and connect at 4800bps of baud rate
    in mapsource the minimus suported us 9600bps, or there are other way?
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 02:24 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  3. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 05:53 AM
  4. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 06:06 PM
  5. Garmin 35 PC USB VS. Deluo USB Receiver
    By SLAYER6669 in forum GPS
    Last Post: 10-03-2002, 12:33 AM
