Results 1 to 10 of 10
Thread: BU-303 not working correctly
    Mik
    Mik is offline
    Newbie Mik's Avatar
    Feb 2004
    Leeds, UK
    Exclamation BU-303 not working correctly
    I have a problem with my BU-303 GPS mouse.
    I have installed it on my pc and laptop, and have the same problem with both.
    After I have installed the driver and plug in the mouse. I have a problem getting my pc/laptop to recognise the com port assigned to the mouse. Using the application that came wit the mouse, I click the ‘scan com port’ button and sometimes it will find the port and others it wont. I have tried connecting using two application, Autoroute and InfoMap. Also tried using HyperTerminal.
    When it does work, it does so for a bout 2 or 3 minuets and the problem persists until I reboot or mess about with the com port settings.
    Is it the unit or my PC and Laptop, they are both running Win2k.
    Thanks for any help,
    Mik
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Quote Originally Posted by Mik
    Mik
    I have one to
    The SPECIFICATIONS
    if it not have bin uset in more than 2 days
    the Cold Start can take 5-15 min
    ref taken form www.g-sat.dk
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Mik
    Mik is offline
    Newbie Mik's Avatar
    Feb 2004
    Leeds, UK
    Using it daily, have left conected to the pc woth the dongle out of the window. The LED will start to flash after about 60secs, but i still have the same problem with it. Even sat out side with the laptop and have the same problem.
    Aug 2004
    I have this exact same issue when i connect my mobile phone to my computer if I have power hungry things attached to the same USB host. might be work unplugging anything else u have, (i assume your not using an unpowered hub)
    Paul
    Oct 2003
    Works fine for me.
    My Microsoft Mappoint saw it easily as a com port, I did have to install all the Windows Updates on one of the computers because I hadn't done it in a while (Windows 2000).
    Try that, if not...you've got a defective one or try another USB slot so it automatically adds more com ports.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    I think its a com port conflict, what other applications use your com ports ?
    check this out, uninstall all of them, install the gps first and then the other applications.
    Things to look out for:
    Microsoft Activesync
    Cellphone software (number updates, phone books etc)
    Bluetooth applications
    and you get the idea, its probably somehting that looks for the com port every few minutes to do a sync / update that is messing you around.
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Mik
    Mik is offline
    Newbie Mik's Avatar
    Feb 2004
    Leeds, UK
    Ok think you might have solved it, i have both the laptop and pc set up the same. will try a few things a let you know.
    Thanks for the help, these fourms are priceless
    Jul 2004
    Mik I am having the exact same problem with mine. Did you find anything more out on this ??????
    Mik
    Mik is offline
    Newbie Mik's Avatar
    Feb 2004
    Leeds, UK
    No, johnnyutah36
    I am moving houses at the moment so havent had a lot of time to mess with anything like this, just keeping an eye on the fourm when i get an email.
    will let you know if i do find anything. should imagine it will be a loong time off yet.
    Feb 2004
    Almeria (Spain)
    In my case, the com port is not recognized by the software from the cd, but my gps software works ok more or less.
    Epia M10000
    PW80
    40GB 3,5"
    Touchscreen 7" Lilliput
    Still "housing" it.
  1. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  2. Put computer into standby/hibernate = firewire cdrom driver stops working
    By psyclobe in forum General Hardware Discussion
    Last Post: 04-27-2004, 11:38 PM
  3. motorized screen stopped working :(
    By corsamel in forum LCD/Display
    Last Post: 11-26-2002, 10:52 AM
  4. Everything working correctly?
    By bgoodman in forum Off Topic
    Last Post: 09-15-2002, 12:13 AM
  5. Someone please help 10 hrs wasted working on 4 x 20 Character LCD
    By Martin S. Shepherd in forum LCD/Display
    Last Post: 05-31-2001, 10:25 AM
