Results 1 to 2 of 2
Thread: Rand McNally GPS Unit Not Working Right
    I have a Rand McNally serial GPS unit connected to a Keyspan USB adapter running Pocke Nav
    It is behaving very wierd. It appears to be behind actual tracking of roads when I approach, and the speed is significantly delayed. What is really odd is sometimes the map will look like I am flying over off road areas, or it will say I am on a completely different road while driving.
    What could be causing this, and what settings should I double check?
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Which Keyspan serial to USB adapter are you using?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Destinator SDK + Destinator GPS Module
    By miguelito in forum GPS
    Last Post: 07-21-2004, 02:48 PM
  3. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  4. Serial GPS unit, does it use pin 8?
    By LittleDragon in forum GPS
    Last Post: 04-15-2004, 06:51 PM
  5. Replies: 4
    Last Post: 09-04-2003, 10:20 AM
